Mechanic did a gas motor swap on 2003 Prius...shutting down after it starts...
Discussion in 'Generation 1 Prius Discussion' started by MilkyWay, Feb 20, 2013.
  1. MilkyWay
    MilkyWay Active Member
    823
    359
    MI
    Long story short I bought a 2003 Prius from the original owner with 130k miles on it. The electric motor was fine and would start but the gas motor was blown.
    I bought a used gas engine from a reputable company, and my mechanic did the swap. He is the best mechanic I've come across but he's clearly stuck.
    He thinks it may have something to do with the trans? I'm not sure exactly.
    When you start it it will immediately shut down. Not sure what is causing it.
    Any experts out there? I didn't see a forum for 2003s or less so I posted here, sorry!
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    I think the first thing to establish is if the engine is running or is it just being spun by MG1. Are there any fault codes and if so what are they?
    John (Britprius)
    bwilson4web likes this.
  3. bwilson4web
    15,991
    Where are you located?
    There may be independent Prius shops around that might 'lend a hand.'
  4. MilkyWay
    823
    359
    MI
    I'm in SE Michigan not far from Detroit. Any specialists in the area?
    What are some possible reasons for the engine shutting down?
  5. sammy8887
    sammy8887 Junior Member
    37
    High Point, NC
    2001 Prius
    I
    One of the posters replied to a similar situation for me and this is exactly what the mechanic needed to know to get it running. Thanks again to Chapman! Might help your situation...
    Technical question -- Engine Swap | PriusChat
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    The engine is not shutting down, as BritPrius said, it is spinning but never starting. The way the Prius ICE starts is the MG spins it up to 1000 rpm's before fuel and spark are applied. This spinning is often confused with starting. If you were able to read the codes, you would get an "engine didn't start" code.
    The possible reasons are:
    No spark, no fuel, no compression, improper fuel mixture etc. The same reasons why any other engine doesn't start.
  7. MilkyWay
    823
    359
    MI
    There are Zero Codes so it is impossible to scan.
    My mechanic is leaning towards the idea that there is something electric wrong with the transmission that is causing it to not to stay running. I would really be screwed if I have to throw a trans in it but it has basically been sitting for months. Since it is a complex vehicle that most people are unfamiliar with, and difficult to diagnosis with absolute certainty.
    Is there something you are supposed to do after doing a gas engine swap? For example, take to the dealer and have them reset the computer? I'm hoping it is something more simple.
    What do you think about something electrical within the transmission that went bad that is causing this issue??? Any input appreciated.
  8. bwilson4web
    15,991
    So when you try to start, the engine turns over and does not start. Do you get a "check engine" light? No codes?
    This suggests the engine ECU is not on the bus or failed.
  9. ChapmanF
    17,200
    That's also what I'm thinking, if you've got a no-start and there really are no codes explaining why.
    A Prius engine that spins for a matter of seconds, then stops, doesn't seem the same as a no-start in a conventional car, but that's what it is. If that's confusing your mechanic, you might steer him to one of the threads on this forum where it's explained.
    From what's reported I don't see any reason to single out the transaxle for suspicion. In fact, the transaxle is what spins the engine while it is trying to start, and that's happening, so there is an indication that the tranny is at least so far ok.
    If you're not able to read ECM codes relating to the no-start, that's a problem on its own; perhaps the ECM is bad, or not securely reconnected to the wiring harness after the swap. There is a diagnostic flowchart in the service manual for many conditions including failure to report codes.
    If the mechanic for any reason is trying to figure this out using third-party service literature, it is probably time to blow the $15 on access to the Toyota service manuals, find the appropriate diagnostic flowchart in the engine section of volume 1, and follow the steps in order.
    -Chap
  10. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    Time the engine when it is "starting" with a stopwatch.
    If it "runs" for only 8 seconds +/- 1 second, it never started, something is wrong, often its P3101 and P3191.
    Does the shop have a Prius aware scantool? (Techstream or similar?)
    Many generic scanners don't read all prius codes.
    If no further information try cleaning out the throttle body and intake manifold.
    Disconnect and reconnect the 12V battery then try starting again.
  11. Rick atl
    Rick atl Junior Member
    26
    Atlanta
    2001 Prius
    Did you ever figure this out? I will pass along a couple of tips in case you haven't.
    Of course, as the guys above say check the codes. The check engine light needs to work indicating the ECU can switch it on. Check all the fuses.
    You can also check for a spark just like an old conventional car- but you need to remove the coil from the plug, stick an old plug in the coil with coil's wire harness still connected, carefully ground the plug to the engine (bad ground may blow electronics if the spark jumps to low voltage wiring). I also grounded the mounting hole for the little coil pack just to be safe. Get someone to try a start and you should see the spark jumping the plug gap.
    Most techs know how to check fuel delivery as well. I figured out an even easier way based on elimination. I know I'll get laughed at or flamed for saying this, but...
    When I first got the Prius and was still fixing it up I had this no-start issue at times. So when it did this, I just added propane to the throttle body to see if it would start. Eureka- yes! it started ok, so I knew it was lack of fuel. No fuel pressure gauge, gas mess,etc. Think propane torch turned on LOW with rubber hose attached. No, I'm not suggesting you should do this but it worked for me. In the old days (1979), I think Honda recommended techs use propane similarly to see if the idle mixture was too lean or rich. (Add a little to idling car and it should speed up 50 rpm, indicating a slight lean idle- normal). I think, unconfirmed, that the Prius will shut off fuel flow if it doesn't see some of the sensor parameters in range. My intermittent no start was caused by a simple vacuum hose leak.
    Rick
  12. ChapmanF
    17,200
    Good thinking! Now that you mention it, I remember setting the mixture that way on my 1984 Ford 2.8L too, as instructed in the manual. As I recall it took a larger flow of propane than I could get out of my small hardware-store torch, until I removed the burner tube and orifice from the valve and just fit a rubber hose right to the valve body where the orifice would screw in. With the orifice gone I was able to use the valve to dial in just the right flow of propane.
    Putting the orifice back before next use as a torch is highly recommended. :)
    -Chap
  13. Rick atl
    26
    Atlanta
    2001 Prius
    The funny thing, to me, was when I first tried the propane thing on the Prius; I turned off the propane flow and the car continued to run. I didn't quite know what to make of this at first; but came up with 2 possibilities: not enough airflow through the throttle body (it was coming in via my vacuum leak); or maybe the ECU just shut off the fuel (for safety or to prevent flooding ?).
    Rick
