3 honks
Discussion in 'Newbie Forum' started by Deepax, Feb 21, 2013.
  1. Deepax
    Deepax New Member
    2012 Prius. I start my car and as I'm pulling out, it honks 3 times. As in driving, it honks 3 times again and again. Them it just honks continually. What does it mean? Where in the manual does it explain the honks?
    Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    12,383
    5,020
    Pacific Northwest, USA
    It means everyone is going to be staring at you wondering why you're honking! :) Any warning lights? Did you spill liquid on your steering wheel? Where are you located? Is it really cold out? Maybe a bad switch in your steering wheel? Find a video / info on how to take apart your steering wheel and clean and inspect everything. In the meantime you might be able to pull a fuse to turn off the horn, but I learned in High School that driving without a horn is really dangerous. Don't do it more than once...
  3. fuzzy1
    10,337
    It means that something related to the horn is broken, and needs repair.
    While you list good possibilities, a 2012 is still under warranty. Let an authorized dealer handle it as a warranty claim.
  4. Deepax
    Deepax New Member
    I'm sure it has something to do with the alarm system, I just can't figure out what it means.
  5. PriusCamper
    12,383
    5,020
    A car horn honking is not a indicator of anything, nor is it a warning. Plane and simple it is a broken car horn that's honking.
    mmmodem likes this.
  6. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Are you sure it's not coming from the cars behind you?
    A common occurrence for a Prius :LOL:
    Blu-ray and PriusCamper like this.
  7. andy_p
    andy_p New Member
    Toronto
    or it's just happy to see you :)
    Blu-ray likes this.
  8. RRxing
    RRxing Senior Member
    2,538
    1,813
    NEPA
    There have been plenty of posts regarding alarm system installs gone awry. Take it back to whoever installed the alarm (dealer/aftermarket?) and have them explain/fix it.
  9. El Dobro
    El Dobro A Member
    7,079
    3,259
    No horns here, they just cut you off.
