Steering recall?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 26, 2013.
  1. bwilson4web
    16,124
    Source: NHTSA Launches Safety Investigations of 1.4 Mil Fords, Toyotas, Hondas | TheDetroitBureau.com
    This is weird as I've not found anything on the NHTSA web site nor other sources. Hopefully, this is just an 'investigation', a rumor of an investigation, that goes no further. What gets me is why anyone in the NHTSA would leak this . . . except I keep getting an 'uneasy' feeling about the NHTSA and their objectivity with Toyota.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If this is true......it can't be good for Toyota.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  4. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Feds weigh safety complaint on Toyota Prius steering and Testing lab asks government to investigate steering failure in Toyota Prius - The Washington Post mention Automotive Systems Analysis in Reston, VA.
    I found some stuff on NHTSA. See Complaints - Search Results | Safercar.gov | NHTSA and Defect Investigations Documents | Safercar.gov | NHTSA. You can find this stuff by searching for 04 Prius at Search for Defect Investigations | Safercar.gov | NHTSA .
    I wonder if this outfit is mixed up and reporting what's already covered by the C0T recall (Information on Steering and Hybrid Coolant Pump Recalls C0T and C0U | PriusChat and many other threads).
  5. bwilson4web
    16,124
    Thanks!
    Would you have a sketch or illustrated parts breakdown showing the steering gear assembly?
    From the write-up, I get the impression there are two shafts that sandwich the rack. I would love to see the documents submitted by Automotive Systems Analysis to understand how they determined there was a difference between a one-of versus a systemic problem. I might suspect it on one incident but would require pulling other units to determine if that is the case.
  6. cwerdna
    12,544
    2,124
    SF Bay Area, CA
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    At the very least, it's a poorly written piece. Citing past episodes, slipping in the word "If" and projecting and speculating on rumor. As well as collaging together rumored investigations of 3 different automakers.
    I'd "try" to keep an eye on this, but I'd say get back to me when the author figures out what he is actually reporting or writing about here.
    There's a lot of "Maybe, Could Be, and If " in this piece.
  8. kabin
    kabin Member
    167
    Scottsdale, AZ
    It's true, we recently received the recall letter.
  9. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I think you're confusing things. See the documents I linked to at Toyota Recalls Certain 2004-2009 Prius models for Steering, Pump Defects | Page 2 | PriusChat.
    From http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM432694/RCRIT-12V537-8967.pdf, there have been two recalls, the previous 60C recall and the more recent C0T recall.
    I never was the subject of 60C but did take mine in for C0T. They just replaced a bolt and didn't need to change the extension shaft.
    The article or Reston folks seem to be asserting that there's a 3rd issue not covered by either.
    Bob, I noticed another document (much larger PDF) has appeared at Defect Investigations Documents | Safercar.gov | NHTSA. I haven't had the time to look it over.
  10. dipper
    dipper Senior Member
    1,242
    252
    When I asked the dealer what they replaced on my Prius, he said the whole shaft, not just the bolt. Must have been all those 100k+ miles since the last recall.
  11. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    It has nothing to do w/the # of miles. See page 16 of http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM432694/RCRIT-12V537-8967.pdf. Whether or not the extension shaft needs to be replaced depends on which one was in your car.
    It also mentions on page 4:"Approximately 50% of vehicles are expected to require shaft replacement."
  12. bwilson4web
    16,124
    Thank you!
    I had an entirely different image but the second report really cleared things up and all I could say was 'WOW!'
    I'm going to have to think about this one. In particular, how to detect it in existing vehicles. If you turn either of our cars on, the steering assist motor comes on and steering torque could mask 'slop' in the shaft-connecting, splines.
    Diagnosis needs to measure any developing 'slop' in the system. Perhaps if the steering assist fuse is pulled and the front rack 'frozen' with a clamp. Then turn the car ON to 'unlock' the steering column and measure the degrees of steering wheel movement with a known torque, a small torque wrench.
    What I find interesting is this quote from the owner:
    Source: (pp. 4) http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM434136/INBC-DP13001-55486.pdf
    Of the owner description, my take:
    1. Cruise control would cancel - the cruise control interface in the NHW11 is handled by a set of resistors and switches. It sounds as if the chaffing was going through the insulation, random cruise control events would occur.
    2. Drift off course - this symptom is similar to the neutral, steering stability of our NHW11 that I mitigated by installing larger diameter tires (still 14" rims) on the front wheels. It is not uncommon for similar symptoms to have difference root causes but the loose splines would definitely lead to this 'wandering' behavior.
    3. Radio reception - some of the largest fuses feed the steering ECU. If slop in the system is causing large numbers of micro-steering corrections, the 12V buss noise would be significant and detectable by poor radio reception. Monitoring the current flow through the steering ECU would reveal the problem.
    Mr. Richwine is one lucky Prius owner and more importantly, swift enough to call in Automotive Systems Analysis. I wonder how he came up with their name. But what is with San Diego: Saylor fatal Lexus accident; James Sikes 'runaway' Prius, and; now this. One is an accident, two is circumstantial (or copy-cat) but three begins to look like a pattern.
  13. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Wow, funny no post on here, (Prius chat), about this abnormality. I see lots of issues but not this one.
  14. bwilson4web
    16,124
    We've had to put up with a lot questionable calls in the past mixed with what can only be called deliberate, anti-Prius skepticism. For example, the inflated risk to pedestrians that led to a public law mandating noise makers in the face of a Prius accident rate half that for the USA fleet. Because of this, separating fact from fiction about the Prius has always been a challenge. But Toyota's hands have not been totally clean and paid a pretty hefty fine for past failures to be up front about a previous safety issue.
    This one report is more than a little interesting because of the early engineering analysis and the six years it took to develop. Furthermore, this car had gone in for a steering recall but no one has been looking for this particular failure mode. Even now, I'm wondering if it could have been detected by just grabbing the shaft and giving it a good shake to detect the worn splines.
    As this becomes more known, the automotive version of hypochondriacs will show up with a seasoning of frauds and hungry lawyers. One can almost hear the mental wrenches out there as someone thinks, 'If I can just take this bolt out, I'll win the Toyota lottery and be on easy street.' It isn't fair or justice but exists.
    We'll see how it develops.
  15. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    That would be putting it mildly. The amount of effort expended to keep Prius from penetrating deeper into the mainstream is truly amazing.
    892,519 was the final worldwide sales count for Prius last year. Those trying to undermine are losing the battle. So, it shouldn't be much of a surprise that there's more stirring of the pot now.
  16. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    I agree we need to be talking as much as possible and to as many as possible, that the government and Americian auto makers are once again hoodwinking the public and attacking the Toyota company. It a no lose senereo for the Detroit gang.
    I mean noise makers for a car because its too quiet! When I heard that my first thought was," what ever happened to look both way before crossing the street." In the end nobody wins, the environmentalists, the gas savers, the people trying to cut costs. The auto industry, there be more inspections, more rules, more government intervention. BIG SIGH
  17. bwilson4web
    16,124
    I was trying to avoid some Marine language that would force our moderators to 'clean it up' . . . while they agreed with the sentiment. <grins>
    Of all the sins of the the anti-Prius crowd, stupid is not one of them. So the Virginia State government is planning a $100/year 'whack a hippy' Prius tax under the guise of reducing gasoline taxes. The anti-Prius crowd won't give up but will simply move their assaults on reality to new 'tall tales' in the hopes no one notices but the rest of this should be discussed in "Fred's House of Politics."
    Going back to the steering failure of this NHW20, the question is 'pattern' or 'one time?' You don't do a safety recall for a fleet if it is a one-time instance that can be traced to a specific failure. Sad to say, the clamping nut torque when removed was not in the original report.
    Hummm, I don't remember seeing the clamping nut mentioned. I'll have to go back and see if it was even on the part.
    In aviation accidents, it is not uncommon to find the torque of fasteners are checked if there is any suspicion that it might have contributed to an accident. Really critical parts (aka., "Jesus Nut") are castled with a safety wire or pin.
  18. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    It sure seems like there's a pattern. Earlier today, I saw a push alert from the USA Today app saying "BREAKING: Exclusive: EPA probing gasm mileage claims for hybrid cars". When I went to their app, there were no details other than the headline. Then later, a story appeared w/few details, not even naming a single model or brand.
    Finally, I do now see this story EPA investigating gas mileage in advanced hybrid vehicles finally w/more details, pointing to the C-Max and Fusion.
  19. PriusInParadise
    180
    91
    Hawaii
    In the Richwine/Automotive Systems Analysis petition, on page 3 of the file, bullet point 4 states that the investigator knew of no intervening repairs to the upper steering intermediate shaft between manufacture and his investigation.
    However, page 19 of the file shows records of a steering shaft repair in December 2006. I suspect that was campaign 60C, for replacement of the upper intermediate shaft No2.
    On page 22 of the file, the photos show that the intermediate shaft separated from the steering column with the pinch bolt still installed. When properly installed, the pinch bolt passes though a groove in the steering column shaft, preventing the intermediate shaft and column shaft from separating. The accompanying text states that the internal splines were worn away on approximately 1/4 of the mating distance. This would be consistent with partial engagement of the intermediate shaft onto the steering column shaft when the pinch bolt was installed.
    This may be a case of improper repair, rather than a manufacturing defect.
    bwilson4web likes this.
