4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    * changed post above
    I think the 'Gen 4' should absolutely be a hatchback (liftback). No need to mess with a formula that is working.
    For many Prius c is a bit too small, v little too big, liftback is right.
    If Toyota made a trunked sedan for Prius (somewhat smaller Cam Hy) people would groan the world over. It won't happen. I think hybridizing small trunked sedans is tough because their trunks are small to begin with and putting 12V and traction battery back there makes trunk too small.
    No wonder hybrid hatchback is best seller. It works well, but Camry Hybrid is no slouch.
    btw, if Toyota breaks the smooth line between hood and windshield as rumored, I'd think that would increase Cd, not good.
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    I think GenIV should be available as Prius liftback and current Prius v, both with plug-in options and a Prius Coupe. After Toyota sold almost 46,000 HyCam last year, the Corolla hybrid would take the role of a Prius Sedan for those who want a trunk, and Auris hybrid as Matrix. Then the Flagship Prius (The NS4)!
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    NS4 looks cool, but I'll bet rear headroom stinks in that thing and cargo room is probably ... bad. Hard to be uber cool and ultra practical at the same time. Roof peak appears pushed forward, more like Gen2 Prius, except the whole car is either lengthened or height is pretty short. Looks cool, but I'll bet it's not all that roomy inside. Neither is a Civic.
    Front end looks pretty short. I think safety is pretty high on family's list, stubby front end not so appealing to many.
    Prius coupe? No way, let Scion make some kind of hybrid coupe in a couple years or so. Coupe is merely a 4 seat car that's hard to get in/ out of rear. Limited market.
    If things go the way they've been, this whole 'Gen 4' thing means the new liftback Prius. First a hybrid, then plug-in option later.
    Prius c and v can mosey along at their 2,900 / month pace. v is offshoot of 3rd gen.
    Hybridized Corolla? Like said before, Corolla already has a small trunk. Stuff a 12V and hybrid battery back there and it becomes miniscule.
    If they make a $21k Corolla hybrid that gets 45 mpg combined, tough sell over a $17k Corolla that has 32 mpg combined.
  4. Sergiospl
    3,938
    1,351
    28
    Good points, but NS4 is a liftback, so the reduced space can be managed. As for the trunk space of the Corolla, They maybe looking at either the Prius c HV battery location,
    or the Prius Plus HV Battery Location, but it's Lithium! The packaging inside the 7-seater hybrid Toyota PriusPlus - YouTube
    cycledrum likes this.
  5. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Just wanted to compare
  6. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    JMD likes this.
  7. Bman83
    Bman83 Junior Member
    39
    Los Angeles
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    All car models seem to "grow" over the years. Standard evolution for most cars but possibly deadly for the Prius. Todays Corolla is huge compared to the 1977 I started with. However, in the Prius family, Toyota has to realize that they must continue a "no-compromises" approach to at least one max performing MPG car. Today that is the Prius, and any "styling" changes that reduce MPG by even a fraction seems to head down the wrong path. It's much too easy to let some other or new car model be the visually enticing hybrid than compromise in MPG one smidgin on a market Toyota has cornered.
  9. Tideland Prius
    16,551
    What if Toyota made the Prius a fastback (like the NS4 or the Audi A7)? I'd be ok with that. You'd still get the packaging flexibility of a hatchback with the battery placement and possibility of under floor storage but you get the sleek look of a sedan. Headroom in the A7 is a bit limited (kinda like the Gen 2 actually) but say in the new Avalon (yeah I know it's a sedan), rear headroom is pretty good given the rakish profile. If Toyota can pull that off, it would be amazing (plus 4WD-i!)
    That does look fantastic. They could easily make that a fastback (like the A7) and keep the hatchback flexibility. The issue with a hatchback is weight (extra hinges and struts vs. a trunk lid) and weight is one way to boost mpg as you have less mass to move from a stop. Of course that means less mass to resist strong winds (I assume a heavier vehicle has more momentum and thus can roll down the highway better, if all else equals, than a lighter car in a situation with a strong head wind).
    Sergiospl likes this.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Fastback - Wikipedia, the free encyclopedia
    Ok, so a MB CLS would be a fastback. Looks like fastback roofs have lower height in rear passenger area. They could retain headroom in Prius, but only by lowering rear seat bottoms which I wouldn't like. Prius has nice rear seat height as is.
    I think Toyota ought to stick with the Kammback shape; don't mess too much with shape or size. Work the interior design over, make it much fressher and sexed up a bit.
    I don't like the HSI gage in the center. I use that thing all the time. Should be in front of driver!
    Other thing is Accord, Civic and Camry have been on a 5 year redesign cycle. Would be nice if Prius was on 5 years also, but looks like 6.
  11. windstrings
    6,280
    378
    Central Texas
    Seems that's why at this point it is what it is. A big secret yes, but the mold is already made.
    About all we can hope for at this point is flexibility in options packages and battery technology.
    Alan.. Sent with Tapatalk 2
  12. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    I really hope this is NOT it. It looks like a old 1975 Chevy Grand Torino. Except the Torino actually looked better. Nothing Prius about this car.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Don't worry, it won't be much like the NS4 shown whose windows are short, headroom in rear seat must be awful and the cargo space would be 1/2 what the Prius currently has.
  14. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Can't say I see the resemblance.
    Prius design will be driven by aerodynamic function which points to the NS4 vs. Gran Turino.
    usnavystgc likes this.
  15. windstrings
    6,280
    378
    Central Texas
    Awe, you took out the fun, we all know the imagination is better than the real thing!
  16. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Really, it's been many years but you know what, it does resemble it
  17. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Any way, as I said the grand Torino is a far better look.
  18. iClaudius
    435
    135
    Kansas
    Yes its been many years. No it doesn't resemble the NS4.
  19. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Well, perhaps we can at least agree that the old Grand Torino is a better looking style!
  20. iClaudius
    435
    135
    Kansas
    What do you mean "we" Kimosabe?
    Gran Turino was a butt ugly dud from birth. Prius is an evolving sleek, high tech marvel.
Thread Status:
