How many miles do you have on your Prius?
Discussion in 'Gen 2 Prius Main Forum' started by clintd555, Jan 26, 2006.
  1. clintd555
    clintd555 New Member
    251
    I'm curious to see who has the most miles on their Prius? Also, what problems have you experienced during owning the car?
    Robotic Lawnmower Forums
    http://forums.robomower.biz
  2. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I just have a bit over 18k on it. No problems yet, and 5k mile oil change interval helps too. If you want to change oil yourself, it's easy to do too with this car.
    I replaced the OEM tires to Goodyear comfortread before winter hits after reading some ppl's posts. And occasional wind noise at highway speeds.
    MPG is pretty good. Got couple of low 60's in the summer. Best one was 63MPG tank (who said they can't get EPA?). And doing mid 40's to 50's now in the winter. I drive 80% highway at about 60 to 70 MPH depends on traffic. Reading posts on PriusChat and knowing how the car works will help you get better MPG if you are willing to learn.
  3. NuShrike
    NuShrike Active Member
    1,378
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Wayne Brown is now well beyond 100k on his '04 Prius.
    Privatenrg.com
  5. rflagg
    rflagg Member
    947
    Springfield, VA
    I'm coming up on 48k already, and not a single problem, just a few 'special service campaigns' (the SSC's) - regular oil changes at 5k intervals, tires replaced (with same make and model as factory originals) at 42,000. Lifetime average around 52mpg.
    -m.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    At 19.5k, doing very well. 60+ mpg in summer, 48-51 winter. Use Mobil 1 oil. Engine compartment is clean. Lifetime average right at 50 mpg.
  7. Tideland Prius
    16,555
    23,000kms, 1¼ years old, 2 oil changes one tyre rotation.
    If you can read japanese, it's probably better to check out the japanese sites where they probably have owners from the original 1997/98 model. I do realise Japanese tend to have lower mileage cars but you know, doesn't hurt to look.
  8. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Three Priuses ('01, '02, '04) have put 140K miles on ME.
    Repairs:
    one map light bulb
  9. jamarimutt
    jamarimutt New Member
    985
    33,000 miles, no problems.
  10. jchu
    jchu New Member
    1,063
    Nampa, ID
    42k miles SSC's done. change my own oil. No problems with my '04
