Wind Noise - I like it.
Discussion in 'Prius c Main Forum' started by filipinoof07, Jan 4, 2013.
  1. filipinoof07
    filipinoof07 Junior Member
    66
    Before getting my Prius C2, I did so much research and so many reviews of the Prius C complained about the wind noise at high speeds.
    But since getting my Prius C 2 days ago, hearing the wind against the car just reminds me of the aerodynamics of the vehicle. One of the coolest aspects of the car is one of the lowest drag coefficients on the market.
    The best part about the wind noise is it's the only thing you hear, you can't even hear the engine when cruising on the highway. I love the peaceful drive cruising on the highway (at night is the best, quiet and secluded roads, and a moonlit sky). I find the wind noise is natural and serene. It's now one of my favorite FEATURES of the car.
    minkus, Prismart, Rob.au and 3 others like this.
  2. stopint
    stopint Junior Member
    22
    Cincinnati, OH
    it threw me off at first...i thought my window was not secure and in place...but i agree with your points
  3. james cook
    james cook Member
    145
    36
    Louisiana
    2025 Prius
    turn on some music.
    only downside is if your talking on the phone, sounds like a tornado to the other person.
  4. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    But then you can't listen to the peaceful wind. :)
    It almost annoys me... I love having the radio off to appreciate how quiet the car is. But I want to listen to the music.
  5. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    Maybe my car is different - I do not notice the wind noise. It is quieter than the BMW I traded for it.
    Prismart, RocMills and vernon birdman like this.
  6. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I was just about to write the same thing when I read your message. Same here. I don't hear it either. My previous car (Versa) was noisier.
    RocMills likes this.
  7. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Good aerodynamics usually makes a car quiet. Check your door and window seals. Keep 'em clean (don't forget the surface the rubber seals close against, too, it needs to be kept clean) so they can seal well. A little silicone grease will help keep the rubber from drying out.
    I've driven a couple of new cs and found them to be very quiet, even at highway speeds.
  8. filipinoof07
    66
    Honestly the wind noise isn't bad. I think it probably messed with my head when I read consumer reviews and article reviews online before I bought the car, that I assumed wind and road noise would be something to notice.
    Thanks for the advice, I'll give the silicone grease a try.
    I think for the most part reviews are noting the wind noise of the C at higher speeds.
    Anyway, here are some of sources I ran into that put the "wind noise" thought in my head:
    2013 Toyota Prius C Reviews and Ratings - The Car Connection
    2012 Toyota Prius C: Real-World Gas Mileage Test
    Prius C Review | 2012 i-Tech Hatch | Reviews | Prices | Australian specifications
    2012 Toyota Prius C Track Test
    The Times Weekly, Joliet Illinois
  9. PriusCinBlack
    PriusCinBlack Member
    145
    61
    I've seen this post get kicked a few times and have decided to mention now that I'm kind of the opposite- I interpret lack of wind noise as aerodynamic efficiency. I think when you're hearing a lot of wind, you're probably not getting your best mpg.
    filipinoof07 likes this.
  10. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    It's all nonsense... because the car itself is so quiet, people are able to notice normal background noises more and with the usual traditional anti-hybrid bias it becomes "intrusive" and "noisy".
    Someone once posted an article that did this but also had actual noise measurements which they then compared to another article for a different vehicle. Same figures but the review text didn't repeat the noise claims.
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    But according to these same sites, almost every other car they have tested has been louder.
    All statistics from the same website, in order from Quietest to Loudest at 70-mph Cruise:
    2011 Jetta TDi Sportswagon:
    Db @ Idle: 46.0
    Db @ Full Throttle: 70.1
    Db @ 70 mph Cruise: 59.1 (man this thing is quiet:eek:)
    2010 Mazda 3i touring:
    Db @ Idle: 35.2
    Db @ Full Throttle: 66.3
    Db @ 70 mph Cruise: 61.2
    2011 Hyundai Sonata 2.0T SE:
    Db @ Idle: 38
    Db @ Full Throttle: 66.1
    Db @ 70 mph Cruise: 62.0
    2011 Honda Accord SE:
    Db @ Idle: 44.4
    Db @ Full Throttle: 70.2
    Db @ 70 mph Cruise: 63.0
    2012 Audi A6 3.0T:
    Db @ Idle: 41.6
    Db @ Full Throttle: 70.9
    Db @ 70 mph Cruise: 63.4
    2013 Ford C-Max Energi:
    Db @ Idle: 38.9
    Db @ Full Throttle: 75.4
    Db @ 70 mph Cruise: 64.1
    2013 Ford Focus ST:
    Db @ Idle: 45.6
    Db @ Full Throttle: 78.4
    Db @ 70-mph Cruise: 64.7
    RPM @ 70: 2,650
    2012 Prius C3:
    Db @ Idle: 42.8
    Db @ 70-mph Cruise: 64.8
    RPM @ 70: 2,400
    2012 Prius V:
    Db @ Idle: 37.9
    Db @ Full Throttle: 73.4
    Db @ 70-mph Cruise: 65.6
    2011 Ford F150 XLT Supercab 6 cylinder:
    Db @ Idle: 42.7
    Db @ Full Throttle: 78.5
    Db @ 70 mph Cruise: 66.2
    RPM @ 70: 2,050
    2011 Kia Forte Koup 6-speed manual:
    Db @ Idle: 44.0
    Db @ Full Throttle: 74.7
    Db @ 70 mph Cruise: 66.9
    2011 BMW 535i Automatic:
    Db @ Idle: 42.3
    Db @ 70 mph Cruise: 67.0
    2011 Chevy Cruze LTZ:
    Db @ Idle: 35.3
    Db @ Full Throttle: 67.4
    Db @ 70 mph Cruise: 67.1
    2011 Chevy Volt:
    Db @ Idle: EV: 27 (Gas: 48.5)
    Db @ Full Throttle: EV: 54 (Gas: 78.2)
    Db @ 70 mph Cruise: EV: 67.4 (Gas: 73.7)
    2009 Toyota Prius:
    Db @ Idle: 40.7 EV, 47.2 Engine on
    Db @ Full Throttle: 70.6
    Db @ 70 mph Cruise: 67.7
    2009 Cadillac CTS-V
    Db @ Idle: 53.2
    Db @ Full Throttle: 73.7
    Db @ 70 mph Cruise: 67.5
    2008 BMW 328i:
    Db @ Idle: 42.7
    Db @ Full Throttle: 76.0
    Db @ 70 mph Cruise: 68.0
    2011 Mazda 2:
    Db @ Idle: 40.6
    Db @ Full Throttle: 78.8
    Db @ 70 mph Cruise: 72.9
    As recorded... the C is the one of the quietest, beating out a Chevy Volt on full Electric and a BMW 535i... just shows me that the "test" drivers are "slightly" biased.;)
    Edit:
    Added 2008 328i, will continue to edit as more information comes along. If anyone has a request for a car, feel free to let me know and I'll do my best to add it to the list.
    Edit 2:
    Added 2011 TDi.
    Edit 3:
    Added 2012 Audi A6 3.0T and 2011 Honda Accord SE
    Edit 4:
    Not sure why I never did this until now... adding the Prius V 2012 and the 2009 Prius.
    Edit 5:
    2013 Ford C-Max Hybrid, 2009 CTS-V
    minkus, garm, Rob.au and 2 others like this.
  12. filipinoof07
    66
    @ ztanos Good info, I hadn't seen this!
    The critics still find that the Prius C makes for "some serious wind/road noise" but it's all relative. And the statistical data shows it, since it's purely objective.
    So @ Rob.au, I'm with ya those review articles are very subjective.
    All-in-all, I've been enjoying my commutes on the highway. And quite a few mornings and evenings I choose to leave the radio off and enjoy the silence and calmness of the drive.
  13. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Awesome work ztanos... that was what I was thinking of, then even more detailed. :)
  14. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    This could explain my issue with wind noise. It's good when compared to these vehicles, but when compared to the closest model I could find to my last car (2011 Jetta TDI) the C is about 9 Db louder at cruising speed. That is either a big difference, or there's something wrong with my C.
  15. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    9db is about 1 volume spot on your radio.
  16. Surrylic
    122
    Winchester VA
    So, barely noticeable? haha who knows then.
  17. Surrylic
    122
    Winchester VA
    But if one spot is approximately 9dB, then wouldn't listening to the stereo at 10 be about 90dB? I can hear the stereo at 10 when driving 70mph, but it's super quiet... And at cruising the car should only be at 64dB? That seems off. For the completely inaccurate record, I downloaded two volume measuring iPhone apps and they both said my car was around 75dB when driving on fairly flat land at 70mph. Stereo and air were both turned off. Sitting still with the car off (slightly windy outside) measures between 40 and 45dB.
  18. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I just meant that it was not significant. :) But the stereo volume ticks aren't linear, so maybe I was accurate without realizing it. o_O I downloaded a dB app on my lunch break and tested it at idle and at 65... (traffic wouldn't let me get to 70 stupid Atlanta traffic...) I recorded 45 at idle and around 61 at 65. Maybe the 4 comes with more insulation? Or maybe the cars near you have poor exhaust and are just louder than the ones that run near us.
  19. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Stolen from Decibel (Loudness) Comparison Chart
    Here are some interesting numbers, collected from a variety of sources, that help one to understand the volume levels of various sources and how they can affect our hearing.
    Environmental Noise
    Weakest sound heard 0dB
    Whisper Quiet Library at 6' 30dB
    Normal conversation at 3' 60-65dB
    Telephone dial tone 80dB
    City Traffic (inside car) 85dB
    Train whistle at 500', Truck Traffic 90dB
    Jackhammer at 50' 95dB
    Subway train at 200' 95dB
    Level at which sustained exposure may result in hearing loss 90 - 95dB
    Hand Drill 98dB
    Power mower at 3' 107dB
    Snowmobile, Motorcycle 100dB
    Power saw at 3' 110dB
    Sandblasting, Loud Rock Concert 115dB
    Pain begins 125dB
    Pneumatic riveter at 4' 125dB
    Even short term exposure can cause permanent damage - Loudest recommended exposure WITHhearing protection 140dB
    Jet engine at 100' 140dB
    12 Gauge Shotgun Blast 165dB
    Death of hearing tissue 180dB
    Loudest sound possible 194dB
    Perceptions of Increases in Decibel Level
    Imperceptible Change 1dB
    Barely Perceptible Change 3dB
    Clearly Noticeable Change 5dB
    About Twice as Loud 10dB
    About Four Times as Loud 20dB
    Sound Levels of Music
    Normal piano practice 60 -70dB
    Fortissimo Singer, 3' 70dB
    Chamber music, small auditorium 75 - 85dB
    Piano Fortissimo 84 - 103dB
    Violin 82 - 92dB
    Cello 85 -111dB
    Oboe 95-112dB
    Flute 92 -103dB
    Piccolo 90 -106dB
    Clarinet 85 - 114dB
    French horn 90 - 106dB
    Trombone 85 - 114dB
    Tympani & bass drum 106dB
    Walkman on 5/10 94dB
    Symphonic music peak 120 - 137dB
    Amplifier, rock, 4-6' 120dB
    Rock music peak 150dB
    minkus likes this.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    So I drove through Tennessee last weekend and the cabin was exponentially louder than in Georgia. Maybe your roads are in worse condition than mine are. Tire noise would make the car louder. The noise underneath this car is much louder than on other cars, so this would make sense.
