Prius charging station may have started Corte Madera fire
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by devprius, Mar 6, 2013.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Well, this is not good:
    Prius charging station may have started Corte Madera fire - SFGate
    "An explosion and fire, which may have been sparked by a Toyota Prius charging in a garage, damaged a two-story condominium in Corte Madera and killed a cat Tuesday evening, a fire official and a resident said."
    Not clear if it is an actual Plug-in Prius or an aftermarket conversion.
  2. El Dobro
    El Dobro A Member
    7,079
    3,259
    It doesn't say if it was a PIP or a conversion.
  3. PriusCamper
    PriusCamper Senior Member
    12,393
    5,026
    Pacific Northwest, USA
    All you plugin Prius owners are a bunch of evil cat killers!!!!!
    lensovet and F8L like this.
  4. PriusCamper
    12,393
    5,026
    The odds of it being plugin conversion are slim to none...
  5. john1701a
    john1701a Prius Guru
    12,806
    5,295
    57
    Sadly, the media may run with this, speculating & suggesting without facts.
    Watch to see if any question whether or not an extension-cord was being used. If any do, which probably isn't likely, will they ask what gauge is appropriate for recharging?
    For that matter, what does "charging station" even refer to? Was it an aftermarket level-2 charger? What about the circuit itself?
    Needless to say, lack of detail makes a mess of the situation.
  6. Jon H
    Jon H New Member
    Northern California
    Tracksyde and john1701a like this.
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    And what exploded?
    Any other PIP owners in the SF - Corte Madera Area?
  8. Jon H
    Jon H New Member
    Northern California
    Probably the Prius gas tank exploded If the car was on fire.. Not enough facts in any of the articles to speculate on the cause. All I know from this is that it's not a 2013 Prius Plug-in. That's good news to me.
  9. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    She does say it's a 2004, but she didn't say anything about Charging.
    The Marin article doesn't mention charging at all.
  10. wjtracy
    wjtracy Senior Member
    11,364
    3,607
    Northern VA (NoVA)
    Right now, nothing can be concluded. Need more information.
    2004 Prius would not be Plug-In unless the owner modified it.
    Only other thing I can think of is engine block heater, which seems unlikely but gets down into 30s I see.
  11. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Just saw this on local channel 5 KPIX (CBS).
    They said it happened Tuesday at 6 pm and that they talked to the owner. He said he was using an aftermarket adapter and not one from Toyota. Very unclear if this means an older Prius with add on battery or a PIP with a 3rd party charger or other EVSE.
    Mike
  12. Francos
    Francos Member
    118
    [email protected] and cwerdna like this.
  13. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    The NYTimes article states that nearly 40,000 plug-in hybrids were sold in Calif. in 2012. Funny that only around 9000 green stickers for HOV access were issued.;)
    cwerdna likes this.
  14. El Dobro
    El Dobro A Member
    7,079
    3,259
    I guess I should buy a lottery ticket. :D
    lensovet and PriusCamper like this.
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Well, this exactly illustrates the potential dangers of DIY or various aftermarket packs. Those folks almost certainly don't have nearly as much expertise (nor resources) in design, design review, testing, safety, safeguards, etc. as major auto OEMs, not to mention the latter could be the target of costly recalls, big lawsuits and negative PR/media attention.
    There seem to by some typos related to the guy's name but About the CalCars Initiative for Plug-In Hybrids currently says:
    [email protected] likes this.
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I feel bad for the cat! :cry:
    Now this guy knows how Boeing is feeling with the "Dreamliner"!!
  17. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    A conversion is only as good as the converter. Until investigated, the cause could be the car, a cable, a connector, or the wiring in the house.
  18. PriusCamper
    12,393
    5,026
    Great point!!! Anyone who has anything to say on what happened at this early stage is pushing an agenda rather than representing facts!!!
  19. PriusCamper
    12,393
    5,026
    Well, I just got this email...
    It's a sad day for a small group of entrepreneurs that helped push us towards our modern day plugin hybrid technology...
    Be well, Deane
    -------- Original Message --------
    Subject: [calcars-news] CalCars' First Prius Conversion Destroyed in Fire
    Date: Thu, 07 Mar 2013 21:54:59 -0800
    Reply-To: [email protected]
    To: calcars-news-yahoogroups.com <[email protected]>
    CalCars' first Prius, converted to plug in by advocates in 2004,
    updated in 2010 with a commercial system, was destroyed in a fire on
    Wednesday. It's a sad end for a vehicle that gave hundreds of public
    officials their first opportunities to drive electric and helped
    inspire a campaign that brought us the Chevy Volt, the Prius Plug-in
    and other plug-in hybrids and extended-range electric vehicles. It's
    also a huge personal setback for its owner, Ron Gremban, CalCars
    Technology Lead.
    (Shortly after it goes out on email, this posting will also be
    viewable at CalCars-News Archive -- there you can
    add CalCars-News to your RSS feed.)
    The New York Times story below, by Bradley Berman, founder of
    HybridCars.com and PlugInCars.com, explains the situation. Because of
    the extent of the damage, there's much we don't know and may never
    know about the cause of the fire. Here are a few preliminary broad points:
    * It's fortunate that no humans were injured, especially Ron's
    partner, Lynne McAllister, who discovered the fire and notified the
    fire department; it's very sad that one of their cats died and the
    other is missing. And the damage to their home is a heavy financial
    setback from Ron and Lynne.
    * This incident has NO implications for mass-produced plug-in
    vehicles. Ron's car used nickel-metal hydride batteries, the same
    battery type used in the original Prius and in other conventional
    hybrids for the past 15 years. Today's production PEVs use
    lithium-ion batteries. This commercial conversion did not use the
    current industry-standard J-plug found in all the fully validated and
    tested cordsets in production vehicles.
    * What happened can be put in perspective when compared to the
    internal combustion industry's record, chronicled by the National
    Fire Protection Association: from 2003-2007, an annual average of
    287,000 vehicle fires, 480 civilian deaths, and $1.3 billion in
    direct property damage. NFPA :: Safety Information :: For consumers :: Vehicles
    * In 2004-2005, our message was that amateurs and engineers working
    in a garage could show how we could have cars that plug in NOW, with
    batteries that were "good enough to get started" and would improve.
    We encouraged the media and the public to imagine how much better and
    safer they would be when mass-produced by automakers. These
    conversions drove home the benefits to drivers, the economy, the auto
    industry, the environment, and national security. (This story is well
    told in early news stories CalCars in the News 2004-2005 and
    CalCars Early Years News Stories , and chapters in dozens of
    books, especially in Sherry Boschert's "Plug-In Hybrids, the Cars
    that Will Recharge America" Books that Focus on or Discuss Plug-In Hybrids (PHEVs) .)
    * This first conversion and many dozens more completed through our
    Open Source Prius+ project proudly announced that they got "100+MPG"
    of gasoline, plus a few cents a mile of "cleaner, cheaper,
    domestically produced" electricity. They and about 1,000 other
    conversions by small companies had a giant impact. They helped reach
    the goals of CalCars, the Electric Auto Association, Plug In America,
    and others: raising awareness, getting opinion leaders the
    opportunity to experience driving electric, and encouraging carmakers
    to mass-produce all types of plug-in vehicles.
    * 80,000 plug-in cars have been sold since the end of 2010
    Electric Car Sales .
    And it's been clear for some time that the era of small-scale hybrid
    conversions was drawing to a close. We still hope that more
    companies will jump into a larger opportunity -- converting tens of
    millions of internal combustion engines to plug in, an idea we
    promoted heavily from 2009-2011
    Join the Campaign to Electrify World's 900+ Million Vehicles . And we still have much
    to do to bring PEVs into the mainstream, through DrivingElectric.org
    and other efforts supported by CalCars, EAA, PIA and allies.
    * Finally, about Ron. He's a talented and resourceful engineer, a
    good writer, and a smart strategist. CalCars, founded in 2002, got
    its most important jump-start when he came on in 2004 and led the
    conversion project and many subsequent programs. He devoted his life
    to this effort from then until he got his Chevy Volt at the end of
    2010. Due to budget constraints at CalCars, he was largely a
    volunteer. Ron's costs in rebuilding his home and replacing damaged
    possessions and his car will not be fully covered by insurance. We
    have already received inquiries from people who would like to help.
    If you would like to donate directly, please reply to this message or
    write to sponsor (at) calcars.org .
    Thanks for all the support and help this community has provided over the years.
    Fire Destroys a Pioneering Plug-In Prius Conversion - NYTimes.com
  20. nhalber
    nhalber Junior Member
    83
    Marblehead
    This is clearly a case for Inspector Cluzot.
