New Mechanical Key
Discussion in 'Newbie Forum' started by mosesk, Mar 9, 2013.
  1. mosesk
    mosesk Member
    124
    17
    Ventura County, California
    I just got a couple of uncut mechanical keys.
    Should any locksmith, even my local hardware store be able to cut them and copy from the master?
    I have read that Walmart does it as well.
    Not sure it's worth a drive down there.
    But is there any possibility that this can be screwed up?
    Thanks
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Yup, they can screw it up. I took a mechanical key to the local hardware store where they messed it up. I ended up taking another key to a locksmith, who did a perfect job for $10 (!). Note that you don't have to use the mini key that fits in the keyfob - an ordinary Toyota key works fine, and can cost more like $2. The problem is with clamping the mini key into the machine, and the skill of the operator.
  3. mosesk
    mosesk Member
    124
    17
    I bought a couple of blanks on eBay for about $4 apiece.
    My biggest fear is that they would screw up my one good key.
    I do have the little tag with the code still attached to the FOB.
    Can anyone confirm that Walmart does a good job for very little money?
    Rob- I am curious what you mean by an ordinary Toyota key?
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Your original key should be safe. It's the accuracy of the copy that can be a problem. When they mess up a copy on one of their blanks, they just try again. When they mess up your $4 blank, you're out $4 even if they charge you zero for the cutting.
    mosesk likes this.
  5. mosesk
    mosesk Member
    124
    17
    Is one of their blanks the same size as the ones I bought and will theirs fit in the FOB?
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    The $2 copies from hardware stores and the like are full size keys. If you want the kind that fits in a keyfob, you have to get it from a dealer or eBay. I keep several full size keys to hand out when someone else needs access to the car. Then I have a transponder key (works in the ignition) hidden inside the car. The ordinary keys lock/unlock the door, and the transponder key works in the keyslot. Gen2 Prius keyfobs all have transponders in them, which are used when they are plugged into the keyslot. I just extracted one from a keyfob and used it to replace the transponder in a Toyota transponder key.
  7. mosesk
    mosesk Member
    124
    17
    RobH- well turns out your prescient. Took it to my local hardware store. The very nice guy who cut the key said that their key-cutting machine was the "Cadillac"of cutting machines and he promptly made a key that didn't work.
    He was smart enough to tell me to try it out before I go pay for it
    He was very nice about it and apologetic and I certainly told him not to let it ruin his day.
    It was one of the $4 keys I got on eBay.
    He did comment that the key is a "little thicker" than the keys they usually cut- I assume he's referring to house/regular car keys, etc.
    So now- what's my next step?
    A "real" locksmith?
    Walmart?
    Dealer?
    Thanks
