Black Ice Tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FranklinS, Mar 9, 2013.
  1. FranklinS
    FranklinS Ach crivens ye scunners!
    190
    94
    Eugene, OR
    Can anyone recommend a tire for my conditions? I may have escaped this year? It is currently 65 degrees. But there is next year coming :eek:
    Here is my weather:
    Snow only 3-4 times a season. Usually under 3 inches and more often 1 inch.
    BLACK ICE (I truly hate this stuff) Happens about 6-8 times a season and I must drive.
    What would be the best ice tire? I am not too concerned about snow, but it likely comes with a good ice tire.
    I would swap out tires/rims each winter so I need a dedicated set of ice tires.
  2. jdenenberg
    jdenenberg EE Professor
    3,937
    1,933
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My choice is Nokian WRg2. Good MPG and great traction in all conditions. They can be left on all year.
    JeffD
    FranklinS likes this.
  3. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    If your place allows it anything with studs. I drive on ice at work all the time and studs make it possible without sliding
    Tirerack has the Pirelli Winter Carving Edge in 195/65/15 for $404 without studs, $464 with metal studs. There is another option that is $6 cheaper
  4. FranklinS
    190
    94
    Eugene, OR
    Thanks! Yes it does:
    • You can use studded tires in Oregon from Nov. 1 through March 31. Driving with studded tires before Nov. 1 or after March 31 is a Class C violation and carries a $190 fine.
    • Research shows that studded tires are more effective than all-weather tires on icy roads, but are less effective in most other conditions because they may reduce traction between the road and the tire.
    • Oregon spends more than $11 million a year fixing roads and bridges damaged by studded tires.
    • When it rains, water collects in the pavement ruts caused by studded tires and creates dangerous driving conditions. In cold weather, that water can freeze and cause extra-slippery roads.
  5. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Yep...studs. I appreciate the maintenance issues, and will pay extra if the state so determines, but I will use them as long as they are legal.
  6. PriusTech
    PriusTech Member
    190
    93
    Reno
    Yokohama Ice Guard
    Falken Espia EPZ
    Studs are a scam propagated by the tire manufactures and the road paving companies. Especially in WA and OR where the roads are usually just wet. Studded tires have worse traction in all other conditions except ice.
    The 2nd gen Prius does pretty well in slippery conditions.
    This winter took a trip to Banff Canada, was there for a week in Feb on the icy snowy roads. They won't let you across the border if you have studded tires.
    tumbleweed and FranklinS like this.
  7. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    Michelin Xi3...is the BEST snow and ice tire evah. Highest rated by Consumers. I've had them on for this crazy blizzard season and had everyone from Subaru's with studded snows to Ford lifted F150 AWDrivers say "Gee...that little Prius really goes in the snow!"
    The new high tech snows have silica in the tread material, like having sandpaper on the tires on ice....very grippy.
    No need for studs, they tear up the road and the new snows are better in all conditions.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    For such rare occasions that you do experience icy conditions, I would look at the Michelin X-Ice Xi3 or Blizzak WS70. Both are better for all other winter conditions than studded tires yet they still do great on ice. They don't tear up the roads and they won't hurt your fuel economy as much nor increase your stopping distance.
    Tire Test Results : Testing the Newest Studless Ice & Snow Winter Tires
  9. fuzzy1
    10,337
    Consumer Reports gives them the BEST rating on snow and ice, but the WORST rating for dry and wet braking, and below average for hydroplaning. See CU winter tires on my photo page.
    If your mix of driving includes more time on wet and slushy roads than on serious ice and snow, some other tires might possibly be a better all-around choice for your mix of conditions. Here is CU's list for performance winter tires. But check them directly for any updates since I snapped this image, read their advice surrounding these rankings, and check other sites too.
  10. iClaudius
    435
    135
    Kansas
    "Worst" among the five best. Very relative. The Michelin Xi3's are excellent in all conditions from direct experience in one of the worst Mid-West blizzard winters evah...which involves a LOT of quick melting slush...the Michelin's do great in hydroplaning inducing slush and melt.
    On dry they are much better than the Avid33 standard tires on wet and dry pavement.
    On the dry, they have a 40,000 mile wear guarantee as good as standard tires.
    If you alternate with regular tires, you should get four years of safe, superior winter driving out of them.
    You don't want "Performance Winter Tires" you want the regular winter tire ratings from Consumers.
    Micheline Xi3 is the top gun.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I have lived all over the Northwest and use only all season tires. As stated above studs are better on ice but only on ice. I would rather just slow way down when I have to drive on ice and have better traction the other 99.9% of the time.
  12. iClaudius
    435
    135
    Kansas
    All Season tires will not cut it in ice and snow. AWD vehicle with all seasons will get stuck where a FWD with traction and new high tech snow tires will not.
    As for new high tech snows vs. studs on ice, the difference is minimal if even noticeable.
    Studded tires are a road damaging anachronism that should be outlawed.
  13. tumbleweed
    4,067
    691
    Eastern Oregon
    Obviously one can survive without studs or special winter tires, we did for years. There were accidents just as there are now but they were usually fender benders because most of us were afraid to go very fast. You can get by on good all season tires if you don't try anything stupid and give yourself plenty of room to stop. Winter tires are much better in snow and ice, but I think they impart a false sense of confidence in a lot of inexperienced drivers.
    I agree, studs should be outlawed.
  14. iClaudius
    435
    135
    Kansas
    Many of us want to thrive not just survive in winter snow and ice, especially, ice, you want to have the new high tech snow tires with the silica impregnated rubber. We always see the AWD's with just all-season tires sliding off the icy ski area road.
    The person starting this thread was particularly concerned about ice, in which case the new tech snow tires are just what he wants.
  15. jdenenberg
    3,937
    1,933
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Nokian WRg2 tires noted by me in the second post in this thread also use a silica rubber compound. Their Winter tires are among the best in the world as well.
    JeffD
    FranklinS and fuzzy1 like this.
  16. FranklinS
    190
    94
    Eugene, OR
    I want to thank everyone for their posts (and links!). You have given me some good alternatives.
    What appears to be discrepancies can be understandable if you look at where the person drives. Tumbleweed is obviously a very good and experienced driver for NW conditions. I would feel safe in a car with him with his all season tires. Conversely, although I have lived in the NW for a long time I do not have the confidence in myself in our "mild" NW winter conditions and would feel much better on a set of one of the new high tech winter tires.
    Thanks again, my friends!
