2006 navigation- override
Discussion in 'Gen 2 Prius Main Forum' started by skynsea, Jan 27, 2006.
  1. skynsea
    skynsea New Member
    Southern California
    I have found the instructions for trying to override the navi and can't get it to work. I have tried so many times when I got in my buddy's '05 I was able to do it from memory.
    Anyone have a similar experience in an '06 or know the solution?
    Thanks in advance-
    Drew
  2. Dripps
    Dripps New Member
    116
    Northern NJ (Sussex Co)
    As you've already found out...this procedure doesn't work in 06. There is no known way right now. Can't wait for the wizards of Prius to figure this out!
  3. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    I sure hope someone figures it out! That was one thing I was looking forward to being able to do...not that I have the car yet, but very soon! How much you wanna bet it'll be discovered purely by mistake? :)
  4. airpolgas
    airpolgas New Member
    108
    The '06 has been out for more than 3 months. Are the Prius wizards having a hard time with this? Does a solution even exist?
  5. Rancid13
    2,452
    I sure hope so! I was bummed when it was discovered that the 04-05 Navi override didn't work on the 06's. :(
  6. Miss_Taz
    Miss_Taz New Member
    153
    Pittsburgh, PA
    Still no solution yet???
    This is making me a bit antsy, as I really LOVE using that override in my 05. I will be severely BUMMED if I lose this ability when my new 06 gets here...
  7. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(airpolgas @ Mar 20 2006, 02:08 PM) [snapback]227442[/snapback]</div>
    I'm sure it's there somewhere. As for the Prius wizards, the override was discovered on the Lexus site. Is the NAV system the same on the new Lexus? If so, has anybody looked on LexusChat (or whatever it's called)? Is there a repair manual that has the procedure on how to get to the Service Menu?
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'm going to copy/paste my reply to a similar question recently posted at PriusOnline. This is a minimally invasive way to access both NAV and BT on-the-go by installing a pair of switches. It's how us "old timers" did it for almost 2 years before the software override was discovered on the '04/'05.
    Ok, here's what you need to know if you're feeling adventurous. I'll just say that this hasn't been tried yet in the '06 to my knowledge, but it's certainly doable.
    First, read through this thread completely:
    http://priuschat.com/index.php?showtopic=456
    The easiest solutions that will cause the fewest problems for you are the following:
    Install a pair of small rocker switches attached to the 2 purple wires shown in this picture:
    then you can turn off the speed sensor wires at will then reactivate them at will.
    It's not difficult, all you need to do is cut the 2 purple wires, tap them connect the switches (I'd cut a couple small holes in the vent cover below the vent and leave plenty of extra wire so the dealer doesn't pull it off and tear everything up. A couple small black switches will be pretty inconspicuous and will be easy to reach by you or the passenger.
    Drilling, tapping and all you should be able to do this in 30 minutes.
