1. avraust@yahoo.com
    Pekin Il
    I traded in my 2006 Prius in on a new 2013 Prius. I have had it for 3 months now and it's developed a few strange problems.
    2013 Prius Problems:
    1/10/13: Went out to the garage and heard something running on the vehicles. Sounded like it was coming from the rear. Entered the vehicle and it was louder coming from the back. Nothing was on in the Prius, so I started it up then turned it off and the noise disappeared. It really sounded like a pump running.
    2/4/14: Turned on the front defroster to clear the windshield, after about 5 minutes I turned it off by it's button; however it would not shut off, even tried pressing the "Off " button but it still would not shut off. Finally I had to shut the car off and turned it back on and it seemed to reset itself.
    2/7/13: Went out to the garage and heard something running which sounded like it was coming from under the hood. Got into the Prius and the whining sound was louder coming from the dash panel. I had driven the car earlier that morning and the battery showed it was at a full charge less one notch. When I started the car up after hearing the whining sound it was down to 1/2. After shutting the car back off the sound disappeared.
    3/1/13: Returned from dinner in our Camry and parked it in the garage, when my wife and I got out of the camry she asked was something running. We both heard what sounded like a pump running with a low whining sound. I went over to the Prius and it seemed to be coming from the rear of the vehicle. I crawled under the rear of the Prius and it appeared to be coming from the gas tank area; I recorded the sound on my iPhone. To further try to pin-point the sound I removed the gas cap. Upon removing it, pressure was released and the sound stopped.
    I will have them addressed when I have the oil changed but was wondering if anyone else have experienced anything like this on their 2013 Prius.
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I believe the noise you are hearing is the vacuum pump for the brakes. Mine does that as well sometimes. The car has its own brains...
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Could the sounds from the rear be the fuel pump? It is inside the gas tank. BTW, welcome to PC :)
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  5. Former Member 68813
    3,524
    983
    US
    I must be an old fart, but it's easier for me to read the pertinent part of the car manual than to type a long, multi-paragraph question on a forum.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    +1 Correct answer! Pump performing a fuel evaporation leakage check.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    The noise in front. The car recognizes your key fob / open the door, and then pumps up the brakes so they are ready for you to start your car. Just my best guess!
  8. bisco
    51,525
    didn't you ever hear voices from your 06?:p
  9. avraust@yahoo.com
    Pekin Il
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    I hear voices all the time :rolleyes:
  11. tach18k
    tach18k Member
    406
    SoCal Beach Area
    I one time my 2012 was making odd noises and beeps, then I figured out I left the car with the keys in my pocket but never turned the car off. Very hard to arm a running car.
