Antenna Missing
Discussion in 'Gen 2 Prius Main Forum' started by skruse, Mar 22, 2013.
  1. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Just turned 130k miles. Went to the car wash and they did not return the antenna!
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    you can get them on Ebay for about $7.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    You got to unscrew them before you go through. Prius Chat sells the shark fin antenna. Cost is reasonable, easy to install, reception adequate, no more antenna issues once installed. Matches OEM paint. image.jpg
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Uh...go back or call The Car Wash and see if they still have it?
    Buy one off E-Bay.
    Or
    Take the opportunity to upgrade to a Shark Fin.
  5. JMD
    3,779
    1,282
    Let us know how it works out whatever you decide
  6. fuzzy1
    10,335
    Have you called them and asked for it? Long ago (different car) I noticed a front license missing the day after a wash. Called them, it was in their collection.
  7. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    gen 11 owner.
    Didn't know they had to be removed at the carwash...
  8. JMD
    3,779
    1,282
    They screw on or off.
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    They don't!!!
    The local car wash, which is a pretty good hand wash, with air dryer, pulled my antenna first time I took the car there for a quick wash, I bitched at 'em, and made them pull the compressed air out and blow the water out of the screw socket! I let them know that if you don't keep it dry, you are going to get corrosion and that will kill received signal strength!
    They did, and NEVER pulled my antenna EVER again!
  10. Mendel Leisk
    40,518
    Maybe sub'ing a short bolt with the same thread pitch and a rubber washer would be good: keep the socket water-tight and protect the antenna.
