Shamed By My Wheels!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by FranklinS, Mar 25, 2013.
  1. FranklinS
    FranklinS Ach crivens ye scunners!
    190
    94
    Eugene, OR
    Had my Prius for a month now and I completely love it! However, this morning I pulled up to a stop light and in the other car was a Gen III Classic Silver Prius. I felt like a cheap clone:( .
    Checking around Craigslist I found and bought a set of these tonight. OEM Lexus 16 X 6.5. Just a minor scrape on the edge of one rim and included the caps (and 225 tires LOL). $200.00.
    Just need to find some good LRR tires. I can't get Mich A/S in 205 X 16.
    Very happy now(y)
    mnml, Chris S and spiderman like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What a deal!
    FranklinS likes this.
  3. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Nice find! Post some pix as soon as u install em:) .
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Nice find. Can't wait for the pics
  5. peterjmc
    917
    189
    Clarksburg, MD
    Are you sure they will fit your Prius? I thought those wheels have a bolt pattern of 114.5x5. The Prius hatchback is a bolt pattern of 100x5
  6. FranklinS
    190
    94
    Eugene, OR
    You are right! I just measured bolt pattern (should have done that when I went out). Because the guy didn't even know what size diameter he had, or model number, I was getting all sorts of conflicting info, including it having a 5 X100 size. Oh WTH, I can use adapters. Cause of the offset I'll be OK.
  7. FranklinS
    190
    94
    Eugene, OR
    If I use spacers/adapter I will run a 20mm offset. 25mm for adapter -45mm wheel = 20mm total offset. Wondering how that will be?
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Wheel fitment is confusing. It's alway best to buy a set of wheels that fit, versus a set you make fit. Wheel bore, offset, and bolt pattern are variables you need to consider.
  9. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Bolt patter should be main concern not spacers
  10. ockevin
    ockevin Active Member
    493
    148
    Orange County
    with spacers your wheels will stick out way too far...
  11. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    With the stock offset and width of those wheels, you might be able to pull it off. However, don't lower your car too much.
  12. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
    Or, you could sell the wheels for a profit and use the money for a set that fits.
    Better than trying to adapt these to fit.
    F8L, sfv41901 and spiderman like this.
