Traction battery at 50%
Discussion in 'Gen 3 Prius Main Forum' started by Mrpcar, Mar 25, 2013.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Just got my car back from the dealer's initial 5000 miles service, basically just oil change I think.
    When I dropped the car off my traction batter was at 80%, now the traction battery is at 50%.
    How in the world did they ran the battery down that low? Of the whole time I owned the car I've never got the battery down that low before, what exactly did the dealer do?
  2. Mrpcar
    542
    253
    Chino Hills, CA
    Just looked at the service receipt, one of the test item was "Perform battery test". I wonder if that has to do with this.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Could be so many things like leaving it in accessory a while, moving it around without kicking the engine on, having it on with the fan running... Even if it went down all the way, it'd just start the engine so its no big deal.
    Sporin likes this.
  4. Former Member 68813
    3,524
    983
    US
    What is it?
  5. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    The bigger question is an oil change at 5000 miles?! Hope you didn't have to pay for that. It should be 10k intervals.
  6. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    I think the initial (first oil change) in new car can be shorter.
  7. rekniht01
    rekniht01 Junior Member
    Knoxville, Tennessee
    ToyotaCare calls for a service at 5k, but it doesn't include an oil change. Just an inspection and maybe the aforementioned battery test. I didn't notice anything with the battery after ours.
    OceanEyes likes this.
  8. BZzap!
    BZzap! Senior Member
    1,607
    878
    5K service is just a routine check of the fluid levels, inspection of sorts and tire rotation. As for the traction battery being in a reduced rate of charge...who knows? As one poster indicated, running it around the shop without ICE start up is a probability.
  9. Mendel Leisk
    40,490
    Geesh, I have the battery flirting with 2 bars most everytime I taxi around in a parking lot, for a few minutes. Or driving at around-town speeds on level roads.
    They likely drove it around the lot a bit, and it was warmed up enough to do it in EV mode.
    And the battery check was likely the 12 volt.
    spiderman and sardog like this.
  10. Mrpcar
    542
    253
    Chino Hills, CA
    The dealer where I bought the car from provides free service I think up to two years when you purchase a car from them. So I got the oil change for free. Invoice said $38 which hardly will break anyone's bank if one need to pay for it. Oil change is cheap insurance. I change them at 5000-7000 miles for all of my cars. However this 5000 mile oil change was call for by the dealer.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    hope the used synthetic oil...
  12. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    They probably put it in "N" so they could push it around the shop as required. Not to worry. You can get it down to about 30% in some situations in "normal" operation. It'll be back at 60-80% in a few minutes of driving. It's not a high capacity battery compared to the energy that can be drawn from it. It's 6.8 A-Hrs (at 200 V).
    Not sure how you are measuring the percent though, as it displays bars. Zero bars is 40% and full bars is 80%. So if you are counting four bars as 80% it's actually 60%, the level the car tries to run at.
    I've seen full bars during mountain descents and once in a while in city driving and one bar once (can't remember what I did to get that). And I never use "N" as it brings up too many lights and warnings. ;)
  13. BZzap!
    1,607
    878
    My first oil change was at 10K and the 5K service was just a routine inspection and tire rotation. The dealer is changing your oil at 5K intervals ??? If they are, it's their own dollar. Toyota will only pay for 10K oil changes for 2 years.
    Mrpcar likes this.
  14. Mrpcar
    542
    253
    Chino Hills, CA
    I didn't realize there isn't a total of 10 bars, I assume it had 10 bars like the gas level. So to me two bar down is 80% :p
  15. Mrpcar
    542
    253
    Chino Hills, CA
    It is on their own dollar. That's why the invoice said $38, but the balance said $0. So I guess the service department bill the sales department? Part of their sales pitch, free service for 2 years... And prior I just thought it was a packaged deal from Toyota, now I know...
  16. BZzap!
    1,607
    878
    Actually, that bar graph is just an "Idiot Graph". No insult intended. I have a ScanGauge on my car and the real world SOC (state of charge) rarely gets over 70%.
    ralleia, JMD, OceanEyes and 1 other person like this.
  17. BZzap!
    1,607
    878
    That's good. I'm going to suck up the expense of doing an oil change in between the free 10k from now on. It's just cheap insurance. I don't care what they say.
    Mrpcar likes this.
  18. Mrpcar
    542
    253
    Chino Hills, CA
    I agree! When I took the engine apart at 100K miles from my 911 to do a top end refresh there were no signs of any ware. All the worn parts were plastic parts, like the timing chain guides etc. I've always changed oil (Mobil 1 0W40) between 5000-7000 miles.
  19. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I always get a major drop in battery whenever I took my car in for service. This is normal.
    Unless free, take it in every 10K from now on (i.e. 15K, 25K, 35K) and do your own service in between. That way, you'll avoid the pricey 30K service.
  20. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    Same here... and no loss of the traction battery - just a momentary adjustment from the tire rotation which disappeared three trips after the service.
    The only time I took mine below 50% was a long conversation with my youngest son on the Bluetooth while parked... had the moment of "Oh ****, what have I done?!" Two trips later and we were topped off and "back to normal.":)
