Aftermarked DRL installed ( pic inside ) how legal are they?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by si12j12, Mar 31, 2013.
  1. si12j12
    si12j12 Member
    64
    Hello all I just installed some DRL from Phillips called "DRL DayLight 4".
    The install was fairly easy and I think lights look good , however I am not sure how
    legal it might be to run these , such as with factory drl or at night with low beams?
    If I run them with factory DRL then i would have 4 separate lights on at one time?
    and if I run them at night then I dont know if I would run into problems with the law since i would have bright DRL and low beams.
    As of now they are set up to turn off when low beams are on and can choose to run the factory DRL or not so i dont think that will be a problem but would like to hear some thoughts and comments?
  2. si12j12
    si12j12 Member
    64
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I confess I never run any DRLs as I never turn off my headlights. But I do not think they are illegal. (Laws will vary by location and we do not know your location so YMMV)
  4. si12j12
    si12j12 Member
    64
    I am in Southern California where cops tend to be a little anal so dont want to get a ticket.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I don't think there is any problem running them with ur factory DRLs. As far as at night with the low beams.....u might have issues as they don't focus the light on the road.....they spread it so they might blind other drivers. I don't see any fogs but if u plant on getting fogs just know that Cali DOT states that u can only have 4 foward light on at any given time.
    On a side note.....I love the Spitfire. It it a '76?
  6. si12j12
    si12j12 Member
    64
    Yes , Im aware of the DRL light pattern and it is why im only runing HID lowbeams now.
    I have the ability to run 2 or 4 DRL at the moment , however dont know if i should.
    And yes its almost like a spitfire its a Triumph GT6 but it is a familly menmers "project" car thats been sitting for years now, thinkig of fixing it up for myself.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Haha.....its a GT6. Kinda hard to tell from here. I was looking for the buldge in the hood. My mom has a '78 Spitfire.....been trying to talk her out of it :D
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
    Probably not legal in CA. But if you want to know for sure, just drive over to the local CHP office and ask. :)
  9. si12j12
    si12j12 Member
    64
    I might just do that.
    Some one I know just got a ticket for not having driving lights on although DRL's were on
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I some times have my LED fogs on with my DRLs & have never been looked at twice.
    I do agree with dogfriend......u could always stop at the CHP & ask.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    V C Section 24403 Foglamps
  12. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    A big confused why you add DRLs to a car that has them as standard?
  13. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Yeah, I thought DRL were standard on all 2012+ Priuses.
    Also I think running DRL + headlight together during the day or night is legal. At least that's the way they are on the Bimmers. The DRL is the angel eye ring, and will stay on regardless if the headlight is on or not.
    However if you drive around at night, or rain (using your wiper) using only the DRL it's illegal and you will get a ticket. Headlight is still required.
  14. prius_cor
    prius_cor New Member
    I think they look great. I am big fan of DTLs
  15. xliderider
    xliderider Senior Member
    8,089
    3,239
    Honolulu, HI
    The Daylight 4 DRLs you got don't dim when the headlights are on, they were designed to be turned off when the parking/headlights are turned on.
    The Daylight 8 DRLs dim when the parking/headlights are activated making them legal for use at night.
    The Prius DRLs also don't dim, so rewiring them to stay on when the headlights are on is also potentially illegal and can throw up a lot of distracting glare for on oncoming traffic.
  16. si12j12
    si12j12 Member
    64
    Yes, this is true ... They are wired now where all DRL's ( stock and aftermarket ) turn off when lowbeam or parking lights are on.
    Better Pics/video to come soon
