2005 VSC after Recall fixes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shenny, Apr 1, 2013.
  1. Yes
    0 vote(s)
    0.0%
  2. No
    100.0%
  3. Repair Battery
    0 vote(s)
    0.0%
  1. Shenny
    Shenny New Member
    I had bought the car Prius 2005 with 182,000 miles, have driven 34,000 with oil changes and replace of tires and brakes. Received two letters for water pump and power steering recalls.
    Took the car to the dealer, reported an acceleration problem. After recalls were fixed, they did not find any problems.
    Drove about 5 miles parked for about 3 hours after that a message shows up in the dash with a VSC and a picture of the car with a ! in the middle.
    Took the car to the dealer and now I have a $4,000 repair! Coincidence! -
    Reports with battery bad cells 4 and 5.
  2. boppo
    boppo Active Member
    799
    139
    Owego, NY
    And what would that repair b? Post more info about your problem, maybe someone can help and they might save u some $$$.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Missed the battery part, did they give u codes for the problem?
  4. Shenny
    Shenny New Member
    It reported with bad blocks 4 and 5
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    The above still aren't codes. What are the DTCs?
    You also posted in the wrong area. I've already flagged your post to be moved.
  6. Shenny
    Shenny New Member
    Car still at the dealer, I will try to get the DTC. Car drives fine, can I drive it to the next mechanic. I'm in Calif. San Gabriel Area.
