That bulb above the highbeams?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by armoredsaint, Mar 6, 2013.
  1. armoredsaint
    armoredsaint Anti-Eco Company Car
    92
    28
    I don't know the official name, but it's right above the highbeams, it stays lit if you just have your side lights on too...BTW, what's the purpose of it since we really don't have DRL's?
    Anyone mod it with a different bulb, if so what's the size? Same ones as the interior map lights?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    That's the parking light.
    Yes, many people have put in an LED bulb in there. Yes, same one as the map lights take.
    armoredsaint likes this.
  3. armoredsaint
    92
    28
    thanks - found some extra lexan LEDS i always have on hand - it was literally a 2 minute mod :D
  4. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    My left one doesn't work half the time, something with the wiring? Anyone else with the same problem?
    Edit: also, what are the led strips of 5 or so lights just below the parking light for?
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Those aren't actually LEDs... they're just shaped like there's something there.
    I suppose you could always bake the headlight, drill out the indents and mount some LEDs in there...
  6. peterjmc
    917
    189
    Clarksburg, MD
    I have a problem where both sides, the 168 bulbs kept going out. A few times I was able to bump the light with my fist and the light bulb worked again. I switched the drivers side to an LED for the parking lamp and a standard 168 for the light above the headlight and that side hasn't gone out at all.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You can get inside the female socket w/a small jewelers screwdriver and pry the brass contacts a bit towards the center of the socket which gives it a tighter connection on the bulb.
  8. Austin5
    Austin5 Go Bruins
    34
    Boston MA
    Same, I would hit it with my fist.
    Just tried a different set of led's with very large connections, and no problems. If it happens again, will do.
  9. Tideland Prius
    16,434
    Hmm, I've put the factory bulbs back into it since the LEDs failed twice (heat issue?). The passenger side is dimmer than the driver's side. It's not particularly noticeable unless you're up close and notice one is more "amber" and one is a bit whiter.
