52MPG
Discussion in 'Prius v Fuel Economy' started by varun, Mar 29, 2013.
  1. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    5 tanks so far on mine...avg 40.2..... I have had at least 100miles @ 75mph with each tank though
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ROFL
    Now, how can I resist an invitation like that ?
    F8L likes this.
  3. varun
    varun Junior Member
    25
    Phoenix,AZ
    2013 Prius v wagon
    456.JPG Took this before my first refill Avg 52.5 miles 456 ;) , keep it up prius v
    F8L likes this.
  4. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    Wow! That's some amazing mileage for a v! Imagine the mileage you could get if you released the parking brake! :D
  5. PLSPUSH
    359
    132
    Tulsa, Okla.
    up to 45.2 (calculated) with the warm weather
  6. varun
    varun Junior Member
    25
    Phoenix,AZ
    2013 Prius v wagon
    parking brake good one :LOL:
  7. Michele de Lucca-Lowrey
    Michele de Lucca-Lowrey Junior Member
    39
    FL
    I now have 2000 miles on my new one and only receeive 38.6 avg.
    STILL waiting for 40 on a noemal day. I can get it temp. by driving like a grandma, but not driving normally like you are supposed to.
  8. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    141
    HTTP 404 Not Found
    Michele de Lucca-Lowrey - With such a French name, I shall assume your are operating you fuel-sipper in the cold northlands of Canada. Your 38.6 MPG number is essentially the MPG of the 1.8-Liter I4 if it were to be operated without the benefit of the Hybrid Synergy Drive assisting it to deliver higher MPG/Liters Per 100 Miles.
    What this tells me is that your gasoline engine is running nearly full time. This may hurt your feelings a bit, but I would guess that it is not your Prius v(vee) that is delivering 38.6 MPG, but one Michele de Lucca-Lowrey's "Lead Foot."
    Yes, I am sure the cold Canadian Temperate Zone climate is a contributor, but the biggest contributor is probably your Gas-To-Go/Brake-To-Stop Driving Technique & Practices. You need to start driving "Hybrid $marter."
    Click on the link to the Ten Tips Guide in Dr. Catgic's signature. Then Read, Heed, Put The Ten Tips To Practice, Top Off You Gas Tank, Reset The Trip Button, Take Two Aspirins, and report back to me when you fill up your gas tank again. If you do start driving "Hybrid $mart," per the Ten Tips Guide, your fuel economy will likely be up into the 40s MPGs when you fill up your tank again.
  9. 1911Tex
    1911Tex Junior Member
    57
    17
    2013 Prius v wagon
    1000 miles on a new v and 47.5mpg.......regular driving 80% city. Very happy!
