jump terminals on a 2013 prius c (under the hood) There or Not
Discussion in 'Prius c Main Forum' started by john roman, Apr 9, 2013.
  1. john roman
    john roman Junior Member
    35
    my door tag says 1/13 and no terminal
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Yessir.
  3. john roman
    35
    hears the thing though ive seen a diagram for it and talked to toyota headquarters and they comfirmed that there is one in the fuse box and in the owners manuel showing how to jump it off via fuse box terminal. mine has neither
  4. toyotechwv
    toyotechwv Toyota Technician
    474
    252
    Princeton, WV
    Should have both fuse blocks tomorrow. I'll post pics.
  5. john roman
    35
    ok tks so now toyota head quarters is saying that no prius c 2013 has a jump terminal on the car.
  6. toyotechwv
    474
    252
    Princeton, WV
    ummmm yeah, tell that to the Habanero C in our showroom..... and every other C on our lot for that matter.
    ztanos likes this.
  7. john roman
    35
  8. john roman
    35
  9. toyotechwv
    474
    252
    Princeton, WV
    Update- Both fuse blocks are on backorder. Should be arriving in next couple weeks. Will keep you posted.
    SPH-D710 ? 2
    denali123 and frodoz737 like this.
  10. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    It's only in the manual. This said the website has two manuals covering 2013, one with the jump terminal and one without*. It would seem apparent that c's manufactured before a certain time don't have it and c's manufactured after a certain time do have it.
    Unfortuntely, it doesn't seem that the "2013" owners posting to this thread are posting their production dates from the tag on the B-pillar when they're saying if they do or don't have it, so it isn't yet apparent from empirical evidence when the change occured.
    * They've made a horrible mess of it on their site currently - it was neater before. It's in the "Steps To Take In An Emergency" section, near the end.
    2012 without jump point (p.475)
    2013 without jump point (p. 477)
    2013 with jump point (p. 479)
    It's not really an issue - if your car doesn't have it, it was manufactured before they started putting them in, and you're in the same boat as all 2012 owners. Your car just doesn't have it - Toyota doesn't need to do anything.
  11. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    My 2013 (made in 12/12) doesn't have them and I really don't care one way or the other. It's still a fine, no a great car, and I have no issue with Toyota making a change after my car was made. I really don't feel Toyota owes me an update, unless there is a safety issue which I doubt. My owner's manual tells me how to jump start the car, that's all I need to know.
  12. john roman
    35
    I understand now my manufacture date on the door jam is 1/13, so i guess they started after that date its no big deal just, would make jumping the car off eaiser thats all. Another member said that i can get another fuse block and plug that in so ill probably do that. I feel that it being a mod or not toyota should put one on if others have it. Does any one know the exact date that they switched it.
  13. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    I can't even remember the last time I jump started a car - it was many, many years ago - before headlights automatically turned off and before interior dome lights automatically turned off. In my last car I got back from a month overseas having just missed the coldest day in Sydney in 60 years, to find the car's original battery - then 7 years old - had quit. The road service guy took one look at it and booked the battery patrol to come and replace it. It had showed no signs of being near death prior to that, but fair enough.
    The Prius will be admittedly more interesting given the usual clues of a low battery will not be present... but if the day comes, to be honest I'm kind of looking forward to giving someone a heck of a surprise when I open a rear door and ask them to pull up there.
  14. frodoz737
    frodoz737 Top Wrench
    4,707
    2,508
    33
    I do not own a C model, but have test driven one as an option for later purchase. This Thread is interesting because it points out and effectivity change in manufacturing that people should be aware of. The only concern I see here is to verify one's Owner Manual matches the location of the jump terminal of your vehicle. But of course everyone reads the book and gets to know their under hood...er uh...under seat...Right? I'm curious to to see the results of toyotechwv's research towards a possible modification, all lawyers aside. He does not have to do this for us and I think we owe him thanks, especially those who own a 2013 C Model. (y)
    Rob.au and ztanos like this.
  15. john roman
    35
    i agree with you thanks alot i want to add the terminal to my prius, i hope i can do it.
  16. novasquid
    novasquid Junior Member
    49
    Northern VA
    i just checked mine, and my 1/13 manufactured c4 doesn't have the jump terminal under the hood.
  17. toyotechwv
    474
    252
    Princeton, WV
    Ok guys, the other relay block finally arrived. Here are some pics of both side by side. One without jump terminal, one with.
    SPH-D710 ? 2
  18. Optical Illusions
    Optical Illusions Junior Member
    42
    Let us know if this can be swap and replace on the 2012 PC please. And if it does could you list the part # for us 2012 owners to order too please :)
  19. Hodr
    Hodr Junior Member
    As a '12 owner (and someone with a history of leaving his headlights on) I would definitely be interested in this. How hard would it be to swap out?
    Also, do the Prius C headlights automatically shut off? I tested with a 5-10 minute trip into the drug store and when I came out they were still on.
    -Hodr
  20. sdnlgm
    sdnlgm Junior Member
    San Diego
    production date 2/13 and + terminal is under the hood in the drivers side fuse box as shown in the image earlier
    Rob.au likes this.
