2007: Dashboard goes dark in cold weather
Discussion in 'Gen 2 Prius Main Forum' started by danjburke, Apr 17, 2013.
  1. danjburke
    danjburke Junior Member
    On some cold winter mornings, my dashboard stays dark. Later, sometimes hours later, it lights up normally. Any suggestions?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    dogfriend likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    You either have a temperature sensitive component, or connection problem. If you cannot get at the circuit board and perform heat and chill testing, a meter swap is the preferred method of fixing this problem.
    While I am quite comfortable doing board level maintenance, you have to first access it in order to fix it!
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Should be covered free at dealer. Call them about "combination meter" problem.
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    KK6PD likes this.
