The Plugin has belt-driven accessories?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Troy Heagy, Apr 21, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    I heard that on a Youtube video and was surprised. I thought the Plugin was based on the g3 platform, which has no belts.
    51,568
    i think there is a belt, not sure. and if there is, not sure what it drives. water pump maybe?
  3. Troy Heagy
    Troy Heagy Member
    1,218
    The youtube video claimed the heater is belt driven, therefore the engine has to turn-on to produce heat for the passengers. (shrug). The non-plug G3 has an electric heater doesn't it? And electric water pump, a/c, etc.
  4. bisco
    51,568
    the heater is conventional in g3 plug in and otherwise. radiator and fan. the ice has to run to produce heat. a/c and power steering are electric.
  5. Troy Heagy
    Troy Heagy Member
    1,218
    Ahhh so no electric heater in any of the Priuses. That's different from the Volt Plugin which uses an electric heater (I think?)
  6. bisco
    51,568
    i think so, at least pre heat while plugged in.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    No Belts! :)
  8. bisco
    51,568
    how does it keep it's pants up then?
    JimPHL, cwerdna, babybird and 2 others like this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Heat in plug-in comes from engine heat.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    :whistle:o_O what pants?
  11. bisco
    51,568
  12. Troy Heagy
    Troy Heagy Member
    1,218
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    Covering my eyes NOW! :whistle:
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    I'm not! :)
  15. n5160u
    n5160u Junior Member
    22
    17
    The PIP has an electric heating element located above the traditional heater core.
    It is listed here in the Prius parts catalog as the "Quick Heater, item #9.
    Its not very powerful but in my area it is usually sufficient provided I don't set the heater output temp higher than 68 degrees. Going above that setting almost heater.gif
    always starts the ICE on my car.
  16. hill
    8,732
    The test mule fleet had heat pumps (and a larger traction pack) . . . . I'd love to pick one of those puppies up . . . for a song of course.
  17. mrbigh
    3,686
    699
    Long Island, NY
    Maybe you can do a" serenade" to Erica...:whistle:
  18. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Toyota calls the small electric heaters in Gen 2 Prius PTC Heaters. I would guess that is the buzzword for Gen 3 as well.
    About PTC Heaters
  19. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Maybe that is why it takes forever to get warm in the PIP vs my 05 Prius?
  20. bisco
    51,568
    i find them both to be the same in our climate. of course, the ice came on right away in the gen II, so heat from electric heater would be hard to identify. but with the ice cold in either vehicle, i have never felt anything resembling heat.
