Horn Upgrade --- DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evpv, Jan 2, 2011.
  1. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I think Steve Kou installed those. IMO, they probably are no better than the FIAMMS, but if you want to spend the $$$ go for it. ;)
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    any sound clips available for the toyota premium horns ?
  3. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Original post updated, broken links are now fixed. (y)
  4. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
  5. mrmackie305
    mrmackie305 Junior Member
    Just did this mod this morning with the FIAMM's following EVPSs writeup and I must say it was very simple! Definitely a great idea to remove the Toyota emblem as it's very convenient to slip your hand through the hole to access the horns.
    I've never changed out the stock horns on any vehicle and was shocked to see the size difference between the stock Prius horns and the Freeway Blasters! No more MEEP MEEP!
    mroadster2k likes this.
  6. jrw45
    jrw45 New Member
    Allentown, PA
    You forgot to mention the year and model.. I am asking for my car which is a 2012 5, not 1 2012 V. The V is a different model.
  7. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Wolo "Bad Boy" Horn. It is essentially a High/Low air horn that has a small built in air compressor. $20 on eBay. To me, it's the best horn for the money. Quite a bit louder than stock, but more than anything, a very pleasing high/low tone.
    - TP
  8. phickson
    phickson Tron Pod Occupier
    89
    31
    Maryland
    EVPV- Many thanks for the great wire-up of the horns swap - I just did my 2012 Prius and although I don't use my horn often - people will hear it now!! Great job!
  9. RaZa
    RaZa Member
    480
    93
    Just bought a set of horns. I'm curious how difficult it will be to install on a 5 with ATP. Others here seem to have done it without much issue.
  10. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I've done it with my 5 w/ATP. The DRCC doesn't interfere, but it does help to have small hands. I was able to do the swap out without removing much hardware to gain access.
    iPad ?
  11. 2fastplus
    2fastplus Junior Member
    56
    26
    Tampa Bay
    Just ordered a set. Quite frankly, I was getting tired of doing hand gestures instead of my horn. Since I was embarrassed to blow the horn I was even more frustrated by the time I could next to the offender to signal my displeasure. Thanks evpv
    xliderider likes this.
  12. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
  13. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    One of my first mods was to install Cadillac horns. Stock horns didn't do it for me.
    Let the mods begin - Cadillac Horns, HID Fog Lights, ! Hubcaps | PriusChat
    I purchased the four horn Cadillac system (notes A C D F) from Ebay for $65. This is my favorite mod...the horns fit in four existing tapped holes in the Prius header panel. Super easy install, used the two factory bolts and two spares I had in my garage. Great mod...nobody expects this car to sound like this.
    Before:
    After (the phone mic doesn't do these babies justice...they are LOUD.
  14. 2fastplus
    56
    26
    Tampa Bay
    FIAMM's came this morning, out of box and installed. Thanks EVPV for the great write up. Took all of about 30 mins from start to button up. Full size car horn sounds great!
  15. andreyco
    andreyco Member
    91
    27
    I can't find the FIAMM freeway blasters for less then $16 each on Amazon, where are you guys getting the pair for $20?
  16. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    get the FIAMM El Grande instead. Pretty much the same thing but cheaper.
  17. xliderider
    8,140
    3,276
    Honolulu, HI
    Here's information on the horns I got from NAPA, they are the same as the freeway blasters:
  18. andreyco
    andreyco Member
    91
    27
    I listened to them on YouTube and they sounded much weaker. Description also says 110dB instead of 130dB
  19. KeithW2
    KeithW2 New Member
    Valley Village, CA. USA
  20. pv7740
    pv7740 Junior Member
    San Diego
    Got the horns. Did the mod in about 1/2 hour. Very straight forward. No more "meep meep" for me. Thanks again OP.
