  1. Fong
    Fong Member
    85
    32
    Arizona
    I might tap to the dome light, that way it only turn ON when I open the door.
  2. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    Yes that is whee most do it. There is a blue wire u can tap into.. Easiest place to find it is the a pillar.. That's where I got mine.
  3. Fong
    Fong Member
    85
    32
    Arizona
    Wait, I taped the the black wire to the blue A pillar wire and it's ON when you turn on your head lights. Which I dislike. Does your do that at night time, when headlights are ON position?
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    So based on ur pics it looks like u tapped the blue wire in the "A" pillar. Where do u have that wire going? Is it going to the blk wire that also has the white wire?
    Also.....did u tap the foot well lights for the pilot lights?
  5. Fong
    Fong Member
    85
    32
    Arizona
    Yes, I connected the black wire (which has black and white) to the "A" pillar blue wire and white taped to the red wire driver side footwell light.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ok so @ night, which LEDs are lit up? The LEDs that shine on the floor or the ones with the turn signal?
  7. Fong
    Fong Member
    85
    32
    Arizona
    On the floor!
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U need to recheck ur wires. If u connected the blue "A" pillar wire to the blk with wht wire & connected the wht wire to the red on the driver foot junction, then it should only turn on with the dome lights.
    Also why did u tap into the footwell light?
  9. Fong
    Fong Member
    85
    32
    Arizona
    I just chat with a member here and he confirm it supposed to be like that. However, again I dislike the feature. I might removed the "A" pillar blue to the dome and see what it does. But here is a pic I just toke a min ago. Testing.jpg
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That's the pilot light only. Not the puddle light.
    When u open ur door, do used more LEDs light up?
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Here is my pilot lights
  12. wotcher
    wotcher Member
    403
    97
    LA
    savior - i like the white pinstripe. i have red on mine. im leaning towards redoing it with white since red looks a tinge ricey.
  13. savior1974
    savior1974 Junior Member
    Yeah I know what you mean, I was going to do red like most other time attack style rims, but I saw the white pin stripe and thought, might as try it. I'm pretty happy with the way it turned out though. Here's a better shot I took when I made a pizza run a few hours ago. Still haven't put the center caps on yet as they are still drying from the black epoxy paint.
    Blu-ray likes this.
  14. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    I like the white rings. I'm tempted to try this myself.
  15. Bullet Salvador
    109
    44
    Los Angeles
    Smartest upgrade to date. Thanks Irv, aka Rude person's, for the brace!
    Annoying install though. One of the bolts was torqued too tight and was almost impossible to remove. I ended bending one of the screws and a 10-15 minute install took 2 hours trying to manipulate the screws.
    Overall, the hard ache was worth every sweat. My car drives smoother on the freeway, especially turning/changing lanes at high speeds.
    This is a must for everyone.
  16. Fong
    Fong Member
    85
    32
    Arizona
    What does these do and where did you installed it? Any images after the installed?
  17. J Dunn
    J Dunn Active Member
    118
    169
    Newport Beach
    I too installed the Rude person's brace! Thanks again Rude person's for the brace and insanely fast shipping! Love it as well, though I found the install to be very easy (sorry to hear yours was not). Took me all of about 10 mins. Also did the wiper delete. I'll try and get a pic of the brace on the car too.
      File size:
      789.5 KB
      776
    C.R.E.A.M. likes this.
  18. Briann1
    Briann1 Junior Member
    Connecticut
  19. peterjmc
    917
    189
    Clarksburg, MD
    Door and center console look good. Seats look terrible though :(
  20. Fong
    Fong Member
    85
    32
    Arizona
    I'm with you peterjmc, not feeling the leather seats quality.
