What have you plasti-dipped or thought of spray coating.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 3TE, May 1, 2013.
  1. 3TE
    3TE Junior Member
    40
    Miami, FL
    I've recently finished coating the whole inside of the cargo tray with black plasti dip. It seems to keep the things from sliding and making noise. While the tray was drying I had half a can left so I pulled the tire and tools out of the wheel well and sprayed the whole painted cargo area.
    I ended up using another can of black for a second coat but the wheel well is soooo much cleaner. The paint is protected from scratches and the sound is deadened. I'm looking to spray more stuff like the emblems, nose and maybe some parts inside on the dash since they seem to scratch easy.
    I'm wondering what if anything you have all sprayed?
  2. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    Just the emblems so far. I've thought of doing my hubcaps and lower bumper area directly below the grill (to make it kinda look more like a 2012+) but haven't done those yet. Whatever you experiment with post up some pictures!
    3TE likes this.
  3. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    I dipped my OEM wheels.
    JANSone and 3TE like this.
  4. 3TE
    3TE Junior Member
    40
    Miami, FL
    I'll post up some pics when the weather clears up here in Miami. That lower bumper area is a good idea thanks!!
    I hadn't thought of dipping the wheels. Can you post up some shots?
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    stuff sounds amazing.. does it infact work for sound deadening?
  6. 3TE
    3TE Junior Member
    40
    Miami, FL
    I've used this on my BMW and it did make the trunk quiet. I spray it right onto the sheet metal.
  7. carlosfpr
    carlosfpr Junior Member
    Hey! Post a Pic. I've been considering a lot to do this.
  8. burstaneurysm
    469
    144
    Chicago, IL
    I don't have a great pic, but you can get the idea.
    3TE likes this.
  9. carlosfpr
    Thank man
  10. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    We should make a dip thread!
  11. 3TE
    3TE Junior Member
    40
    Miami, FL
    I thought this was the dip thread.
    dogfriend and F8L like this.
  12. burstaneurysm
    469
    144
    Chicago, IL
    I dipped my hatch emblems last night. I might redo them, as they didn't turn out perfect...
    ncmm87507 and 3TE like this.
  13. 3TE
    3TE Junior Member
    40
    Miami, FL
    Looks good. I like how you only sprayed the chrome bits and not the blue.
    Did you have to remove them or did you spray them on the car?
  14. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
    Hehe, you look like ur avatar. :D
    F8L likes this.
  15. burstaneurysm
    469
    144
    Chicago, IL
    Sprayed em on the car. I masked with painter's tape so I didn't get overspray anywhere, but otherwise, it went pretty well. The best part is how nicely it peels off from where you don't want it.
    I sprayed the entire Toyota emblem and then went in with a toothpick to peel away the dip from inside the emblem.
  16. 3TE
    3TE Junior Member
    40
    Miami, FL
    Takin my can outside now...
  17. burstaneurysm
    469
    144
    Chicago, IL
    Do I?
    Wraiththe, ockevin and F8L like this.
  18. burstaneurysm
    469
    144
    Chicago, IL
    Good luck!
    And remember, if you screw it up, peel it and start over.
  19. xliderider
    8,125
    3,265
    Honolulu, HI
    Yep a dead ringer. :D
    Thanks for that. (y)
  20. burstaneurysm
    469
    144
    Chicago, IL
    Finishing the job...
    iPhone ?
    ockevin, peterjmc, F8L and 1 other person like this.
