Prius Charge Problem - Clipper Creek Stations
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pepboy2, May 3, 2013.
  1. Pepboy2
    Pepboy2 New Member
    Having an issue charging at recently intalled ClipperCreek stations. I charge fine at home with the factory device, charge fine at ChargePoint public stations, and charged fine at the Clippercreek stations everyday until suddenly the car won't charge just at the CC stations. Others can charge at those CC stations, but mine won't. These are free stations with no access card needed. Up until this week, the charger would start upon plugging in. It does not appear to be a timer issue since the otehr stations start right up and immediastely charge. Odd that for two weeks it worked fine, and I can charge at other lcoations but not now at these stations, even though others can. Any similar experiences or solutions? oh yes, the connector defintely seats based on the "click" you get when you plug it in. Thanks!
  2. 3PriusMike
    3,095
    2,417
    Silicon Valley
    Where are these located?
    Maybe you used up your free charging :)
    Mike
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Does the yellow icon/LED next to the plug on the car light up immediately after plugging in the handle/connector?
  4. Pepboy2
    Pepboy2 New Member
    Located at my employer. Electrician checked the power and that is flowing fine. No restrictions on access. Odd.
  5. Pepboy2
    Pepboy2 New Member
    No yellow light. Doesn't come on at all.
  6. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Is it possible that you pushed the timer?
  7. Pepboy2
    Pepboy2 New Member
    Made sure I didn't do that.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Even with the timer on, the yellow light should still come on and then shut off.
    If the light doesnt come on at all, that seems to me its a Clipper Creek hardware problem.. maybe one of the pins in the J1772 handle is messed up? Something with the signaling?
    SAE J1772 - Wikipedia, the free encyclopedia
  9. mrbigh
    3,686
    699
    Long Island, NY
    Agree !!
  10. Pepboy2
    Pepboy2 New Member
    If there was a probelm with one of the pins in the J1772 would it still charge at all? Or would it be a unique problem only for Prius PIH vehicles? Have seen a Fusion and Leaf charge no problem.
  11. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I'm not an engineer, but apparently, there are some slight differences/variations on how manufacturers implemented the standard. For example, the earlier version of the EVSE that came with the Volt would not work on a PiP at all, but it would work on a Leaf. The Leaf and PiP EVSE, however, would work on a Volt and Leaf.
  12. Pepboy2
    Pepboy2 New Member
    Interesting... I need to get another PIP here to test. That might yield some facts. Thanks!
  13. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . I'm assuming you reset the brick? Did the brick show voltage to it, a red light.
    Rebooting the J connector a few times may help. If your cable works fine at home, then there may be a compatibility problem as previously stated. Strange that it worked the first time tho.
  14. Pepboy2
    Pepboy2 New Member
    SOrry for being new to all this... What is "the brick?" Is that the Clipper Creek box or somehting on my PIP? Thanks!
  15. Rebound
    Rebound Senior Member
    3,992
    2,638
    Portland, OR
    Maybe bring a can of compressed air and blow out any possible dirt in one of the connector pins.
    You could also call Clipper Creek.
  16. Pepboy2
    Pepboy2 New Member
    Have called CC and talked with one of their techs. He's stumped. There are four charging stations and cannot get one to work, plus they are new (3 weeks old) so don't think dirt is an issue, but will try it anyway. Thanks!
  17. Andyprius1
    2,327
    859
    Cool CA
    . The referred "Brick" is simply the heavy part of your cord with the reset, with CC maybe you were using their cord. On charge point either cord can be used. Since the chargers are new, it's very likely one has a glitch.
  18. Pepboy2
    Pepboy2 New Member
  19. Andyprius1
    2,327
    859
    Cool CA
    . You are most welcome.
  20. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I am considering purchasing a Clipper Creek 25 AMP level 2 EVSE. Can you tell me what model is having the problem? I would like to avoid purchasing the same or similar model.
