Eibach Lowering Springs, who's got them?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriBlack, May 9, 2013.
  1. PriBlack
    PriBlack Junior Member
    Im considering ordering a set of Eibach lowering springs and was wondering what everyones thought's were on them. Are they comfortable, does the car handle better and what would the drop look like on the car?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Randydid's Prius dropped on Eibach ProKit.
  3. peterjmc
    917
    189
    Clarksburg, MD
    I'm on Eibachs. The ride is similar to just about any lowered car that I've owned. Smooth roads are great and the ride isn't bouncy.
    If you were to get lowering springs, I would also recommend you get a rear swaybar installed too.
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Bullet Salvador likes this.
  5. PriBlack
    Ok, that looks great. I thought the eibachs were a little lower in the front that the TRD?
  6. PriBlack
    Anyone have eibachs on stock wheels?
  7. Sfcyclist
    1,621
    375
    SF, CA
    I thought that thread had it in there? I guess you're still after Eibach's huh?
  8. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I think he meant lowered on stock 15s, whether Eibachs or Plus springs.
    OP, not Eibachs but to give you some idea:
    Shibikku likes this.
  9. Bullet Salvador
    109
    44
    Los Angeles
    If you have a warranty go for TRD lowering springs as not to void the warranty. I believe you can get them for $205-15 shipped online. Here is one spot, I forgot the other online retailer, but price is similar with less shipping and handling.
  10. Sfcyclist
    1,621
    375
    SF, CA
  11. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    No aftermarket product can void the warranty unless they can prove it directly caused the damage and the burden of proof is on them, not you (per Moss-Magnuson Act).
  12. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Here is mine on H&R with stock shocks, and 17" limited edition Toyota 10th Anniversary wheels, very happy.
    H&R give a slightly lower drop on the front which I like as then when you have people in the car it level out. Unlike most other which seem to be level or lower on the rear.
    Car actually feels less bangy over bumps, certainly less travel in the springs so little less body roll, but as another mentioned, you should get a rear anti-sway.
    Michael Craig, hw30_ and F8L like this.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    The drop with Eibach and TRD is the same.
    Here is my old one with stock springs and MB Motoring 15" wheels
    Here is my old one on TRDs with PIP 15" wheels.
    BigPete likes this.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    FWIW, we measured the drop with a set of H&R springs and 2 sets of TRD springs on three 2012 Prii and the H&R springs were lower in the front but higher in the rear. Great for a little more sporty look.
    People who have installed Eibachs and measured the difference showed the same numbers as the TRDs.
    BigPete likes this.
  15. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    It would make sence that TRD and Eibach are the same as from what i understand is the TRD springs are only available in USA through Toyota USA and Eibach springs come from Eibach USA.
    I'm in UK and Eibach do not list the Lowering spring kit in their catalogue here, I emailed them and they said they are available but come from Eibach USA so need 4-6wks for delivery. Gave my local dealer the TRD lowering spring part number, they replied not on our system as USA only part number and we cannot get.
  16. Bullet Salvador
    109
    44
    Los Angeles
    Thanks for the link. They're by far the cheapest I've seen to date with shipping considered. Cheers!
  17. Sfcyclist
    1,621
    375
    SF, CA
  18. Sfcyclist
    1,621
    375
    SF, CA
    oh and if you change your mind to just get TRDs I agree with most of the positives everyone else said about them already. They work well with stock shocks, comfy considering the drop,def. improves handling and drop IMHO is just right. Highly recommend getting 17's if your goal is aesthetics and improved handling.
  19. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    What's the F/R drop you measured for H&R vs. TRD/Eibachs? I know they're advertised but I'm curious about your real-world measurements.
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    I don't remember the exact numbers from that day. I'll ask Sean. I was too busy taking pictures. :)
    I have the numbers for my drop somewhere. I want to say it was 1" all around.
