How do you update the dvd for NAV?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by windstrings, Feb 2, 2006.
  1. windstrings
    6,280
    378
    Central Texas
    The manual just says to check with the dealer....
    Do you put it in the regular dvd?... how is it loaded?
    Once its loaded, how do you interface with it?
    If I missed it in the manual.. please let me know the page #.
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    On my Honda,
    - you pop out the tray
    - take out the old DVD
    - put in the new DVD
    - close the tray
    Done. The system reboot itself. Watch the sceen and follow instruction. :D
  3. windstrings
    6,280
    378
    Central Texas
    Humm.... I'll have to look closer, but I haven't yet noticed where the old one is?
    I'm assuming it has nothing to do with the 6 disk cd changer for the stereo?
    It must be somewhere else.
  4. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    I'm not positive, but I believe it's in the unit on the floor under the driver's seat.
  5. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    It is under the driver's seat. Move it forward and you should see it on the floor from the back seat. There is a snap on cover that needs to be removed, just press on some tabs. This will reveal the DVD slot and a eject control. I don't recall whether you push or slide the eject control and you might need to have aux on.
  6. AlphaTeam
    AlphaTeam Member
    643
    Earth
    You have the newest version available. So do I and the @#$@#%@# is out of date!!! We had a MAJOR highway FINSISHED 1.5 years ago and it did not make the latest DVD. I called to complain and I was told to buy the new one when it came out at the end of this year. Geee thanks Toyota I'll give you a few hundred bucks because you suck.
    Rumor has it someone succesfully made a "back up" I wish I could find the link to the directions. I'd love to "back up" the new one when it comes out.
  7. windstrings
    6,280
    378
    Central Texas
    I may try to create a backup when I get the time..
  8. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Someone made a post on how he did it. I know it wasn't just a standard copy. He had to do some song and dance with Nero to get it to work. I think the original post was before the forum melt down last fall. I did a search and could not find it...maybe some can.
  9. AlphaTeam
    AlphaTeam Member
    643
    Earth
  10. Stairman
    Stairman New Member
    42
    The maps for GPS systems are always a year or so out of date. The mapping companies release updates every 3 months, but the GPS software side has to integrate the map with their particular navigation software. The GPS companies seem to try to update once a year, but with the various time lags, plus plain old error, the product may be as much as 2 years behind when it comes out. I'm sure Toyota doesn't produce the maps or the software.
  11. windstrings
    6,280
    378
    Central Texas
    I have nero and I'm sure it will work if you know the right settings.. but I'm going to try clone dvd2... its pretty good about making an exact duplicate... if its protected, I may have to rip it first.
  12. windstrings
    6,280
    378
    Central Texas
    A promising way to try a burn with Nero may be to use high quality disks, then burn in an .iso image or .nrg. Then you can pull from that file to burn.
    The beauty of that method is that Nero makes an exact copy!... Cd's that are bootable etc that normally has info that wont' transfer because of invisible files all get transferred with that method.
