Bubble in the Rear right sidetire, side wall. Do I have to change both the rear tires.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Viji Thuppul, May 9, 2013.
  1. Viji Thuppul
    Viji Thuppul New Member
    I have a 2010 Prius with 25K miles on it. Recently, I found a small bump on the side wall of the rear tire. Toyota service center advised me to change the rear tires. I have Yokohoma AVID S33D BW P195/65R15 tires. Now my question is:
    1. Do I have to change both the tires? Is it ok to change only one tire with same specifications?
    2. Will it have to be the same yokohoma tires or can I try any other brand?
    Thanks
    Viji
  2. El Dobro
    El Dobro A Member
    7,088
    3,270
    You can change just the one bad tire, but stick with the same tire model, if possible.
    TsKarma and PLSPUSH like this.
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    You can do either.. but if you change both now, you can prolong changing all 4 next time as this pair will have 25k miles less. then you can just buy 2 next time around.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  5. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I would never replace just one half worn tire. No way. At least two, probably time for all 4 soon anyway
    JMD likes this.
  6. JMD
    3,779
    1,282
    kenoarto likes this.
  7. JMD
    3,779
    1,282
    Just for the record, Costco has good deals on tires, Discount Tires, and a local place Evans Tires.
    If you know what you want shop at 3 different places and try and get the best deal.
    For Evans I call the call center, they tend to give a great discount.
    They ship the tires to the store, and the store installs.
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    Then again, maybe the OP doesn't have the funds to change more than one tire right now. ;)
    JMD likes this.
  9. JMD
    3,779
    1,282
    There is an old cliché, Money doesn't buy happiness.
    I never understood that.
    Money can circumvent many a problem, one being not having any. :)
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Replace 2 if you can. Save the good one as a spare in case you have a problem again.
    At a minimum replace that 1 with same brand tire and make sure it's placed in the rear.
    If I don't like the brand tires for whatever reason I'd replace 2. If I like them and plan to continue using them then I replace the 1. I don't like OEM tires because they tend to be pricey, so I would replace 2 of a different brand if I were you
    Be glad you don't have 4WD or AWD. Then it'd be mandatory 4.
    JMD likes this.
  11. kenoarto
    398
    Chicago, IL
    Then again, the OP drives a 2010 Prius and that sure wasn't cheap. Tires with uneven wear, that may be near or at the end of their life cycle, are not the best place to take chances. FWIW my original Goodyear tires only lasted 28,000 miles and that wasn't at all unusual. My "new" set of General Altimax's have lasted more than 40,000 (warranted to 55,000) and are due to be replaced soon, too. Safety has great value.
    JMD likes this.
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    Until the OP comes back, we won't know what his situation is.
  13. JMD
    3,779
    1,282
    Good old Viji may be worth more than all of us put together.
    He may drive a Prius to create peace and harmony with the world.
    Hey Viji no offense, just having fun. :)
  14. El Dobro
    El Dobro A Member
    7,088
    3,270
    He'd have a PIP then. :p
  15. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I put on a new set of Bridgestone Ecopia on my 2010 at 46000 miles. (The factory set was 85-90% done at this mileage.). Your Yokohama at 25k is at about 50% wear already. I'd suggest to change at least two. Same brand and model is preferred if you like the Yokohama that you currently have on the vehicle. If the new pair is not of the same model, the two must always be mounted on the same axle. It is recommended to put the new pair on the drive axle in order to get the maximum vehicle control - in Prius is the front axle because it is front wheel drive.
    I read that the Ecopia is not rated the best by the Consumer Report but I found it the best balance on price and ratings. If you want better cornering and traction but don't mind paying slightly more, there are some other brands you can consider. There are many threads in this subject in the forum.
  16. RAL
    RAL Member
    66
    34
    FYI keep a bit of an eye on the rest of your tires...I had a Michelin do this and the rest of them all developed large bulges is less than 2000 miles. Bad batch I guess and yes Michelin stood behind their tires and replaced them all no cost to me.
    RAL
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    Not to nit pick but the above information is only 50% correct.
    You should put the matching tires on the same end of the vehicle but the new tires (or ones with most tread) should NOT go on the front. The tires with the most tread should always go in the rear of the vehicle. The advice above is not consistent with current knowledge. This is not an attack on toyolover but we need to make this very clear.
    New tires should always go on the rear of the vehicle regardless of where the drive wheels are located!
    Tire Tech Information - Where to Install New Pairs of Tires?
    Only Replacing 2 Tires? - Discount Tire
    Tire Safety Starts Here - ATS | Tire Industry Association
    mtbiker53, kenoarto and El Dobro like this.
  18. ursle
    ursle Gas miser
    1,049
    192
    NH
    Hogwash:) I would never put a 30% or more worn tire on the front with new rubber on the rear, I want to turn when I turn the steering wheel, this is a case of the tail wagging the dog, putting the worn rubber on the front, where it will wear roughly twice as fast as the rear tires is just a way for the manufacturers to sell more rubber, I wouldn't be surprised to see the insurance companies chime in and require it in the future.
    With stability control and abs cars don't switch ends unless there's an idiot behind the wheel, as I mentioned, I want the best rubber on the wheels that do the steering.
    So, in summary, you are more likely to have an accident if you put the worn rubber on the front, and you will be buying many more tires as you will be wearing out front tires at an unprecedented level, all the while being in more danger then necessary, just use common sense;)
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    Can you provide evidence to back up your opinion? I've already presented mine. I can link you to many more if you like. :)
    mtbiker53 likes this.
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    Well, let's look at the op
    25,000 miles, one bad tire
    Common sense say's replace both tires on that end of the car
    Common sense say's put the new tires on the front, you don't want to lose traction while turning with worn tires on the front
    And common sense say's why put the old worn rubber on the front where it will wear faster, causing more frequent new tire purchases
    Do I need evidence to show a new tire on the front has more traction when turning, or evidence that worn tires on the front will wear out faster then new tires on the front?
    ABS and traction control won't let you get into a skid or slide unless you willingly override the systems.
