Traction battery rebuild question
Discussion in 'Gen 2 Prius Technical Discussion' started by YY4U, Apr 6, 2013.
  1. YY4U
    YY4U Junior Member
    85
    The lowest voltage module is 7.68v, so I'm discharging them all to 7.6v. I set an hour wait between cycles so I could stop it before the charge cycle. So far so good.
    I'm going to wait a week before reinstalling the battery and check for any modules that may be discharging too quickly. Since I've got it apart and (at this point) am in no rush and whatnot.
    Now the deal is, htf do I put this thing back together. It's been weeks since I took it apart and I've got hundreds of parts and screws and various components all over the garage. Wth was I thinking, Betty?
    2 y's
  2. YY4U
    YY4U Junior Member
    85
    Got it all back together last night. All lights and the fan are still on. I drove it for 20 mins and so far no go. It also seems to sometimes go into some kind of limp mode and has no power. If you restart it runs good for a while.
    I didn't want to clear the codes with my scanner, I wanted to see if the lights would go out by themselves. I'll clear them now and see how long it takes for them to reappear.
    The lowest voltage module was 7.65, the highest 7.85. Perhaps this is my problem. If any of the guys with experience in this are still following this thread maybe you can give me some ideas.
    Is it possible my problem is not with the traction battery but something else? It would really suck to buy a $1k salvaged battery only to find out it wasn't the problem. So many possible issues here.
    Does anyone here have any idea how long you would need to drive the car for the lights to go out, if they were going to go out? Would .20 difference in voltage be enough to keep the light on?
    Oh, one last thing: When I first started the car, I didn't notice the fan being on till I drove it for a while, now it's on constantly. Also, at first, the ICE would shut off and run on battery only, now it seems the gas motor runs all the time.
    yy
  3. YY4U
    YY4U Junior Member
    85
    Also, last night, whenever I would power the car up, there was a loud beep. Just one.
    I just went to clear the codes, and one second after clearing, the beep sounds and the red triangle immediately pops on. Before the rebuild, after clearing the codes, the lights would stay off for 30-60 secs. Now they come back on instantly.
    There is a very real possibility I have not connected something properly.
    Thoughts, anyone?
    two y's
  4. YY4U
    YY4U Junior Member
    85
    When you first power up there are 3 clicks coming from the battery, then the beep. It's like it's running a test that it instantly fails.
    I just checked my wife's '05 and it makes the 3 clicks, but no beep after.
    Too Wise
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There are many instances of people not getting the safety disconnect plug on the battery properly clicked into place. Since you got it together before, perhaps this is not the case this time. You are doing fine so far, but clearly a detail has been overlooked. Somewhere a jumper loose? A wire misplaced?
    You would be way ahead with this project if you had the mini VCI reader (or the one from Autoenginuity), and actually finding out what the DTCs being set are. Otherwise, no one will be able to say for sure what's up. When in a jam, more info! It's cheap and comes quickly (eBay).
  6. ryousideways
    ryousideways Member
    35
    100
    Merritt Island, Florida
    It sounds like the batteries are not quite balanced. Did you connect it in parallel after balancing all 28 batteries? When I check my voltage after leaving it connected in parallel, every module was exactly 7.80 volts with the occasional variation of 7.81 volts. I would remove the pack and check the voltages again. If they are fairly close together ( .15 volts ) I would connect the pack in parallel. If it is farther apart run a single dsch<chg cycle to all of the batteries. Make sure they all come up to the appropriate charge.
    Take some pictures and post your set up. It sounded like you may have had a loose connection with one of the battery modules. I know how frustrating this can be.
  7. YY4U
    YY4U Junior Member
    85
    I'll check it out. What about the scanner that connects to your phone via bluetooth?
  8. jdenenberg
    jdenenberg EE Professor
    3,935
    1,932
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Torque Pro ($5) on an android pad or phone should do the job. Priidash (free) on a Linux or Windows machine is also a good choice for use with a good Bluetooth OBDII dongle.
    JeffD
  9. YY4U
    YY4U Junior Member
    85
    I did not connect in parallel, as that is what I thought the discharge to 7.6v was supposed to do. Which brings up the question, at the risk of exposing my ignorance: If the modules all discharged to 7.6v, why do they all read higher now? Some as high as 7.8?
    And a question about connecting in parallel, would you connect the positives and negatives on #1 and #28 together to form a loop? Does that make sense? What I mean is, you connect all the positives, but when you get to the last one do you run a jumper back to the first?
    Would a difference of .20v in the modules really cause the triangle and hybrid light to instantly light up? Should I drive the car on the interstate for a while? I'm kinda afraid to take it on the highway now. But I got AAA.....
    YY
    pics coming
  10. jdenenberg
    3,935
    1,932
    Trumbull, CT
    2020 Prius
    LE AWD-e
    YY,
    When you did the discharge, how did you measure the module voltage? You need to measure the voltage at the module terminals to eliminate the voltage drop in the discharge load wires. A recheck of module voltages after you finish (with no current draw) is also a good idea as each module has an internal series resistance and differences in series resistance can cause voltage imbalance under high load/charging currents in active use.
    JeffD
  11. YY4U
    YY4U Junior Member
    85
    I just set the DC6 to discharge to 7.6v. I checked them with my $5 Harbour Freight multimeter and chalked up the differences in voltage to inaccurate readings on the cheap meter.
  12. jdenenberg
    3,935
    1,932
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The DC6 connection leads do have a voltage drop that can cause differences. I measure the module series resistance (read module voltage drop with a 1 amp discharge current) to determine that all 28 modules (Gen2) have comparable series resistances.
    JeffD
  13. ryousideways
    ryousideways Member
    35
    100
    Below is a picture of my parallel set up. The black wires represent the negative terminals. I connected all the negative on one side and ran a alligator clip to connect to a negative terminal on the other side. As long as all the negatives are making proper contact you should be solid.
    The crazy wires you see going over the top was for the positive terminals. I took a single speaker wire and ran it back and forth over the top. I would strip the wire and loop it once around the positive terminal before running it to the next one. I used the nuts for all the terminals to keep the wire in place. You just have to make sure none of the positives make contact with the negative connections. Double check everything as you are placing the wiring. Wait a few hours and check the voltage of each of your modules. You will notice the voltage will start to equalize with all of the batteries. Mine took about 6 hours.
    A difference of .2 volts was all it took to throw the triangle for my Prius after I put it back together the the first time around (had not balanced the modules then.) The modules must be balanced properly. I would not bother driving the car until you get the modules equalized.
  14. YY4U
    YY4U Junior Member
    85
    I'm going to break open the battery pack and look for anything loose. If I don't find anything I'll do 1 discharge/charge cycle on them and try to get the modules in better balance. Maybe I can figure out how to connect them in parallel to get voltage perfect. I'm not convinced my problem is caused by a .2 difference in voltage, but at this point it seems like the next best thing to try.
    If this doesn't work I'll get a better scanner that can give us some real info.
    Here are 2 pics of my setup on the last go 'round. If I don't have to replace any more modules I'll just leave the pack in the car. From the 3rd pic you can see there is enough room to get to everything. Moving the pack in and out of the car is difficult and probably when you are the most vulnerable.
    Is it necessary to remove the bus bars from both sides?
    yy
  15. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    To even out the voltages on each module you do need to remove all the bus bars.
    Then connect all the positive terminals together and all the negative terminals together. Let the battery sit like this over night, this will equalize all the module voltages, the higher voltage modules effectively charge the lower.
    A voltage difference of .2 volts or more on a pair of modules will throw a code.
    John (Britprius)
  16. ryousideways
    ryousideways Member
    35
    100
    In order to connect it it parallel you will need to remove the bus bar from both sides yes. Just pick up some simple speaker wire to make a harness for wiring parallel. Just remember, positive to positive, and negative to negative.
    When charging/discharging, did you make sure to leave the top and bottom black compression bars installed and tight?
  17. YY4U
    YY4U Junior Member
    85
    Yes, the bars were connected. I'll start the balancing process today. Thanks, everyone.
    yy
  18. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Folks, just replacing and charging/balancing modules will not make your pack work properly unless all modules have similar Internal Resistance and usable capacity. If you don't have have a good method of measuring IR, and measuring voltage UNDER LOAD you are probably wasting your time. Measuring voltage at rest doesn't really tell you too much. (think of the 12V battery on a normal car, it can register 11-12 volts with a voltmeter but is useless at starting the car...that is why good 12V battery testers put the battery under load)
    YY4U has spent countless hours trying to "self rebuild" his pack. While I'm sure it has been a great learning experience, others should note that rebuilding a Prius is battery is not as simple as "buying slices on Ebay and bolting them into the battery enclosure".
    If you are looking for a project, have a lot of spare time and patience, and want to learn new things, go ahead, Do it yourself. But remember, many DIY's install and remove the battery multiple times before getting it right. (aka "whack a mole") Be prepared to be without your Prius for many days (possibly weeks).
    If you just want your car to work, buy a complete rebuilt battery from an experienced rebuilder with a good warranty.
    flxcon and cwerdna like this.
  19. YY4U
    YY4U Junior Member
    85
    Sideways, when connecting in parallel, why did you connect the positives differently from the negatives? Is there a reason to go from one side of the pack to the other with every module? Why not just connect all the positives on one side and run a jumper over to the other, like you did on the negatives? I've got the bus bars off and stripping wire right now.
    yy
  20. YY4U
    YY4U Junior Member
    85
    I couldn't agree more. The learning curve is much too great to recommend anyone attempt this project just for one vehicle. Buying a rebuilt or salvaged battery is the only way to go. I would never have even started this if I didn't view it as "going to school", as I intend to do more of these if I can master the procedure.
    yy
    TheDoof likes this.
