ENTUNE RESET PROCEDURE or Recalibrate Nav (w/ Entune Function) Do at your own risk!
Discussion in 'Prius c Audio and Electronics' started by wmo168, May 8, 2013.
  1. wmo168
    wmo168 Member
    239
    South Florida
    ENTUNE RESET PROCEDURE (w/ Entune Function)
    DO THIS AT YOUR OWN RISK!
    Reset the extension module.
    (1) Display the "Navigation Prompt Volume" screen.
    (2) From the "Navigation Prompt Volume" screen, touch the corners of the screen in the following order: Upper right → Lower right → Upper right → Lower right → Upper right → Lower right. [​IMG]
    (3) Select "General" from the Entune system status display screen. [​IMG]
    (4) Select "Reset Extension Box" from the "General" screen, delete all personal data from the head unit.
    HINT:
    • This will remove all personal data from the head unit.
    Gorgozola likes this.
  2. Dylan Murphy
    Dylan Murphy Junior Member
    28
    Columbia, SC
    Pardon the rudeness, but is this real? I've not heard of this menu before. Also, there isn't really a navigation prompt volume screen is there? Just an overlay when you turn the navi volume up and down right? I also have no idea what the extension box/module is.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I don't know if this works or not... haven't had a need to try it. But there is a navigation prompt volume screen. Makes her louder or quieter as you need it.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I just checked on my c Three (with Display Audio) and you're correct; there is no navigation volume screen, just the adjustment overlay. Perhaps the OP's information is for the Entune system on a different vehicle, or on the high-end nav system.
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You go into the Volume settings. I have done this before (when my dealer set it they had it on full... the first time I used it, I thought my ears were going to explode when she told me to turn left). But it isn't individualized.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    But there's no access to the OP's service menu from there.
  7. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yeah, I wasn't sure about that. I hadn't tried it. But I knew the volume setting was there.
  8. wmo168
    wmo168 Member
    239
    South Florida
    Where is NAVIGATION PROMPT VOLUME screen?
    :confused: :confused: Yes there is, SETUP -> GENERAL -> NAVIGATION PROMPT VOLUME, on that screen is how you get to the special menu. See the instruction below.
    From the Prompt Volume menu you hit the BLANK SPOT from what I said in the 1st post ... Because the service menu is HIDDEN, it will bring up once you follow the steps.
    ftl and ztanos like this.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    OK, that works = would've been handy to have this in the original post. :)
    As well as the Reset, which I didn't try, there's some interesting info there.
  10. Dylan Murphy
    28
    Columbia, SC
    Ah sorry, I was unaware of that, thus my question. I'll have to check it out.
  11. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    WMO do you do this already????
  12. Air_Boss
    Air_Boss Senior Member
    4,169
    1,169
    New Yawk
    Not applicable to the 57011 HU and YY050 Extension Box on the 2012 Prius v.
