Headlights stay on??
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by pat767, May 22, 2013.
  1. pat767
    pat767 Junior Member
    63
    I've just been advised by the security guard (here at work) that my headlights are on.... I parked there over 5 hours ago. Don't they turn off by themselves?
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    yes they're supposed to. Mine do,What year Prius do you have?
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    As long as you open the driver door. If you reach in through the passenger side and turn the car on to roll up a window they will not shut off.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Also if you open the drivers door BEFORE you turnoff the car, they never go off.
  5. pat767
    63
    oops
    That was the mistake. Luckily, they're LED and the battery wasn't drained.
    PLSPUSH likes this.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Pat you can turn off the delay, so you can immediately see if the headlights go off. It defaults to 30 seconds, but can be set to 60 and 90 seconds or turned off (0 seconds)
  7. Don39
    Don39 Junior Member
    Jim, how do you do that?
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I suspect it will vary by level, Two, Three, or Five, but we both have Threes, so ours should match.
    In Setup, choose Vehicle, then scroll down with the double down arrows, and choose Headlamps Auto-off Timer. Then you have your choice of 30, 60 or 90 second delays or off (for a 0 second delay)
    Did that work for you?
    I find this video that shows how to adjust the delay, but my software never looks just like this. (I suspect it is a v Five) The ideas are correct if you are not bogged down by details.
  9. Don39
    Don39 Junior Member
  10. Don39
    Don39 Junior Member
    Thanks, worked fine.
  11. Jzerocsk
    Jzerocsk Member
    108
    31
    PS - Zero seconds actually turns the lights off as soon as you open the door.
