Broken EVSE dust cap
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davidbw, May 25, 2013.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    The dust cap on my EVSE broke off the little plastic retaining strap. Is it possible to get a new cap with strap and install it on to the EVSE?
    51,897
    i was wondering when we would see the first of these. sorry, i don't know the answer.(n)
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You could always trade in the car for a 2013.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    Another great reason to tell the wife. I broke the plastic cover I need another car. I will have to remember that! :D
  5. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    OK we are so funny. Take it easy.Op.:) Check with Toyota part dept.
  6. bisco
    51,897
    looking at it today, i would say if you loosen the screws, the end of the strap will pop out and you can pop a new one in. should be available as a part. fyi, my L2 evse came without one, and i'm not sure you need it.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    I never use mine but again mine is in my garage out of the weather!
  8. davidbw
    davidbw Member
    110
    29
    May be I should buy a Tesla instead.
    Kit Shah likes this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Sweet Idea!:D
  10. bisco
    51,897
    that's the ticket.;)
  11. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    I want to remove that from mine, I never use it, and half the time it dangles against the car paint.
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    I checked on some of the on-line parts catalogs and didn't see the cover listed. Check with a dealer.
  13. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Never use mine either, and hate when it come off the hangers and dangles against cars paint....
    Mine is inside garage though too.
    Not sure I would even bother worrying about it.
  14. El Dobro
    El Dobro A Member
    7,088
    3,270
    The cap was made to attach to the cable, so just clip it on when it's not in use. When I use it at work, I lay it on top of the plug, so it's not hanging.
  15. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I don't call mine a dust cap so much as an anti-spider cap. They seem to like just about any opening.
    iPad ? HD
  16. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I had mine permanently attached to the cable as well, to avoid touching the paint when plugged in. Definitely call your local dealer, they should be able to find out. Swapping out everything else attached to that dust cap with a Model S is not a bad idea tho ;)
  17. rcsting
    rcsting Toyota Fanatic
    282
    112
    Gold River , California
    The part number is 82821-47250 Toyota list price is 10.89 Hope this helps
    Tracksyde likes this.
  18. DLee
    DLee Junior Member
    81
    Mine broke off a year ago, a week after I got the car. There was not a pn for the cap then, so Toyota gave me a whole new charging cord.
  19. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    You can easily fabricate one, or go to the Hardware Store and find the same size.
  20. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    I had also wondered when that would happen. Glad they have a part number. I do not use it since I use the charger indoors and they have a charging station at work.
