Speedometer reads metric, cant change it. Help!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by soberups, May 27, 2013.
  1. soberups
    soberups Junior Member
    My wife's 2012 Prius C has all of a sudden decided to display its speed in Kilometers Per Hour instead of Miles Per Hour. I cannot find any reference to changing it back in the owners manual. I spent an hour messing around with various settings but there is absolutely no way that I can find to change it back. Any help would be appreciated, I dont want to spend all day taking it back to the dealership for a warranty repair if there is a simple way to fix it myself. Thanks.
  2. Optical Illusions
    Optical Illusions Junior Member
    42
    LOL easy solve... On your steering wheel, look for the TRIP button and just hold that down for 2 second. It will switch back to MPH. You can switch it back to Kilometers if you hold it down another 2 sec vice versa.
  3. soberups
    Thank you. I was going nuts. Sometimes its the simplest solutions that are the hardest to figure out.....:)
    RocMills likes this.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This has happened to a ton of people... if you want to feel better about yourself just do a quick search on the subject and you'll find all the stories.
    minkus and RocMills like this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You could just keep it in KPH and fool yourself into thinking you are going vroom vroom! :)
    I drive in KPH all the time, even in the states. Just easier to relate real world speed to numbers for me. Of course keeping up with math skills converting the mph limit signs to kph limits in my head is partial entertainment for longer drives. :)
    minkus likes this.
  6. Species5618w
    Species5618w Member
    140
    Can you change the units of the gas mileage between MPG, L/100Km and km/L as well? I haven't figured out a way.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I can`t comment on the C specifically, but on all the liftback models, no. The MFD does the calculation and it is either programmed to give you MPG and Fahrenheit temperatures OR L/100km and Celcius. No way to switch between them that anyone has found. But swapping a MFD from another region does change the readout.
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I want to say that I remember seeing this... but I think I saw it on the first day of ownership... so who knows. I'll check tonight, unless someone beats me to it.
  9. Mendel Leisk
    41,003
    One page 183 of (2010) Owners Manual:
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    This has been answered, but they are looking for the MPG to l/km or some such... plus... our car doesn't have this button.
  11. Mendel Leisk
    41,003
    Sorry, lost track of this being the c forum.
    ztanos likes this.
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Checked this on my way home. There is an option to change from Miles to KM, but it only applies to the maps... unfortunately... I'm not sure why this wouldn't be an option. It's barely a line of code extra.
  13. Species5618w
    Species5618w Member
    140
    Thanks. Yeah, they should really open source the damn thing. And why not put a Nexus 7 in instead of entune?
    I plan to buy a BT OBDII and mount a Nexus 7 somehow.
    ztanos likes this.
  14. daveinscv
    daveinscv New Member
    Valencia, CA
    Tried trip button . Did not work. i.e. still km/h.
  15. fuzzy1
    10,337
    Those instructions are probably specific to the 'c', not your PiP.
    I don't have a PiP, but suspect it is more similar to my Liftback. Is there a cluster of three buttons just to the right of the steering wheel, to adjust the clock and speedometer? One of them should have a Km/miles marking, press it.
    #15 fuzzy1, Mar 31, 2015
  16. Mendel Leisk
    41,003
    What fuzzy said. If you think about it, a dedicated button is virtually necessity: you do NOT want to be wandering around in menus looking to switch something that fundamental.
