5w-30 syn MPG vs 0w-20 syn MPG
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Jun 6, 2013.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    It has been about 5,000 miles since my last oil service and it occurred to me that I should try 5w-30 synthetic (instead of 0w-20) to see if there are any trackable differences in fuel economy. If I were to do this, I would run Mobil 1 5w-30 for 5,000 miles and use "Trip B" to compare.
    Per the owner's manual, Toyota does allow for the use of higher-viscosity oils if the vehicle is operated under high-speed/high-stress conditions, so I would not be doing anything terribly outrageous. Plus I am out of warranty already, so I am on my own.
    Has anyone used 5w-30 synthetic oil in their Gen III, as opposed to the recommended 0w-20?
    anonymous and mmmodem like this.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Sounds like an interesting experiment. If my car ever starts to consume oil that requires me to top up between OCI then I'll be switching to a heavier weight oil. It'll be nice to know what kind of fuel economy hit I would take.
    anonymous likes this.
  3. Former Member 68813
    3,524
    983
    US
    I'm not sure anyone have done 0W20 -> 5W30. IIRC, plenty of people did 5W30->0W20 in 2nd gen. That should give some ideas. The MPG difference will differ with ambient temps and driving style (city/hwy, trip length, etc).
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    I had 5w30 Dino oil and didn't see a difference in mpg
  5. Bill Norton
    Bill Norton Senior Member
    2,136
    730
    MONW, Ks.
    How would you factor out ambient temp changes?
    FE tracks temp.
    If you could knock out two oil changes ( 10k ) during the hot summer months you might have some good data.
  6. The Critic
    3,193
    2,330
    CA
    Here in Monterey, it's a fairly constant 50-65 year 'round.
  7. Former Member 68813
    3,524
    983
    US
    I think difference should be like 1%. Can't reliably measure that outside a lab. Short tripping in very cold weather could show bigger difference though.
  8. Bill Norton
    2,136
    730
    MONW, Ks.
    "Here in Monterey, it's a fairly constant 50-65 year 'round."
    Dang,,, Never mind.
    I hope you know how lucky you are !!!
    Merkey likes this.
  9. Mendel Leisk
    41,009
    Isn't 5W30 or something similar spec'd in Australia?
  10. Former Member 68813
    3,524
    983
    US
    0w20 through 20W50 is good to go down under.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I think the Toyota spec gives a nod to local custom where government regulations don't discourage it. Traditionally, some Australians would have used bitomen in their engines if the could have gotten it to pour out of a can.
  12. AwesomeAccessory
    AwesomeAccessory New Member
    Holbrook, New York
    I just put 0w20 in my 08, usually use 5w30
    car seems to be revving really high, or maybe I am just oversensitive and looking for trouble with my oil change
    happened immediately after oil change, should I empty it and refill it with 5w30---- or is this all in my head?
  13. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    ...well winter would have been a better time for the 0w-20 experiment in a Gen2. But I believe Toyota USA has said it is OK so you shoud be OK. You want to drain after 5k miles, according to Toyota USA.
  14. AwesomeAccessory
    Holbrook, New York
    yeah I grabbed it for my Altima, and just grabbed two to make life easier (oh well!)
    could this be why its revving high? almost like it's not shifting into first gear, a real struggle.
    maybe ill just put the radio louder -- that oughta fix it
  15. The Critic
    3,193
    2,330
    CA
    Just wanted to follow up on this matter -
    I did an oil change last night using 5W-30 synthetic instead of using 0W-20 synthetic.
    For the record, I used Quaker State Ultimate Durability 5W-30 synthetic.
    From a mpg standpoint, it is too early to tell, but I still got 49.5 on my trip to Sacramento this afternoon. Repeated short trip driving may yield different results though, so we'll see.
    Other than that, I did notice that the engine is noticeably quieter at idle. Perhaps that being at 110k miles makes the engine benefit more from thicker oil?
    I plan to run this fill for 5,000 miles, replace with the same, and then send in a sample after another 5,000 miles (at the 120k mark).
    anonymous, CR94 and Mendel Leisk like this.
  16. bisco
    51,561
    it took you two years to pull the trigger?:p
  17. The Critic
    3,193
    2,330
    CA
    Yup.
    iPhone ?
  18. Mendel Leisk
    41,009
    Thanks for posting. Look forward to the results. :)
  19. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    Were you having a consumption issue as well?
  20. The Critic
    3,193
    2,330
    CA
    No significant consumption - and judging from what I've seen, I am quite lucky about that.
    I have gone down to 5k oil changes and the oil level never dropped more than 1/4 qt between changes.
    iPhone ?
