Any fix for rough ride in a 2011 Prius Three
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by surfer7382, Jun 5, 2013.
  1. BZzap!
    BZzap! Senior Member
    1,607
    878
    Way, way, too, too many personal, physical issues with you to find the right car for you in this price range. Most all cars now a days are designed with handling as the primary goal of the manufactures and engineers. As a result you're going to get a firmer ride in most mid-priced cars. You need a car with ride control.
  2. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    This. You've had it two years and now you're griping about the ride? How many miles are on it? What kind of driving do you do?
  3. surfer7382
    surfer7382 Junior Member
    Yes, we have had the car for a year and a half. I want to make it better so I don't have to get rid of it..
    I did not think that having physical issues negated trying to work with what I have.
    As stated previously, it has about 5500 miles on it, and it is mostly city driving with one trip to another state on interstates. Hubby does most of the driving and he uses eco power mode. I use power mode, but I am not a hot-rodder; I just don't like the feeling that I am hauling a trailer whenI step on the gas.
    I have had issues with the ride from the get-go, but thought that I would get used to it and that it would not be a problem.
    This is a last ditch attempt to FIX IT instead of gettnig another car.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Shocks are normally good until 100k miles. At 5,500 miles, it may be defective or you drive in very bumpy road (doubt it is that bad). Try to get them to replace under warranty.
    Change them out and see if it gets better. Front struts are $97 each. Rear shocks are $34 each. You can get all 4 with ground shipping for $286. There will be labor to install which any local shops can do.
  5. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    [I have had issues with the ride from the get-go, but thought that I would get used to it and that it would not be a problem.[/quote]
    Ding, ding, ding! We have a winner!
  6. surfer7382
    Ding, ding, ding! We have a winner![/quote]
    Do you have any relevant suggestions or do you just like making fun of people?
  7. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    Well, it's not the car. It's you. My "relevant suggestions" would be check tire pressure and adjust to factory specs, look into a softer riding tire, maybe look into some kind of seat cushion, or just getting a different car.
  8. surfer7382
    It is my car, so the problem IS the car. That's why I'm here.
    I don't understand why it is so difficult to understand that I want to try to FIX it, IF POSSIBLE.
    Tire pressure is low as previously stated. Service dept says everything hunky-dory with suspension.
    Softer tires are being considered.
    Now as to the SUSPENSION, from what I have read here, it is my understanding that NO ONE has ever gone and tried to have their Prius suspension modified?
  9. peterjmc
    917
    189
    Clarksburg, MD
    You should ask your dealer to test drive the same make and model of the newer cars and see if those feel the same as yours. This would help you understand if what your feeling is a normal characteristic of the car or if there might be something indeed wrong with your suspension that the techs are missing.
    I have a Five with the 17" wheels and low profile (less forgiving than the 15") and my car drives fairly smooth.
    ForestBeekeeper likes this.
  10. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Let's start with what is your previous car?
    Does your previous car ride smooth?
    Everything is relative.
  11. surfer7382
    done this am; no major difference
  12. surfer7382
    as st
    as stated above, gen 2 Prius (2005); quite a bit smoother than this
  13. bedrock8x
    1,483
    137
    Does not make sense to me.
    If you think a Gen II smoother than a Camry Hybrid, somethings wrong.
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If I read it right, the issue started 1.5 years ago when the car was new. You just want to fix it now and not sure if Toyota will do it under warranty, right?
  15. peterjmc
    917
    189
    Clarksburg, MD
    Nice! So looks like we can rule out that your issues with the suspension are due to faulty parts workmanship.
    I see you resolving this in a few different ways...
    1) find an automotive upholstery shop to add extra padding in the driver and passenger seats.
    2) consider installing a wider and more comfortable tire and run air pressure at the factory recommended settings.
  16. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Suspension mods to improve handling or load capacity are common. Mods to soften the ride are not.
    Softer spring rates run the risk of allowing the car to bottom out easier. These cars have little ground clearance and thus limited suspension travel.
    A Camry or Avalon would probably be the smoothest Toyota models to consider. Given how few miles your car gets in a year you could maybe trade across to one of those preowned, even if it had 30,000 or 40,000 miles on it. It's unlikely that you'd wear one out in less than 15 years.
    Food for thought...
  17. surfer7382
    Yes, the problem was there from the get-go, and it appears that it is jsut they way they are designed,a nd whatever parts one car gets pver another,sicen ther ARE variations. I KNOW Toyota won't do anything, but I don't care. I am willing to pay IF I think it will help.
  18. surfer7382
    Thanks for that info on the suspension mods!
  19. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Agree, when I replaced the original Yokohama tires with Goodyear fuel max, road noise and roughness went down about 50%. I initally saw about a 2 mpg drop with the Goodyear fuel max tires, but mpg seems to have returned to normal now that they have 8000 miles on the tires.
    The Goodyear tires at 44 psi are still much quiter and smoother riding than the original Yokohama's at 36 psi.
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    That's a good point. As tires worn out, the ride will become shitty. However, he only has 5,500 miles in 1.5 years. That's like 3,000 miles per year.
