Odd Shift into Neutral at Bottom of Steep Driveway
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by metalheart, Jun 12, 2013.
  1. metalheart
    metalheart Junior Member
    Foothills east of Sacramento
    I have a 2013 Prius-III. I have a steep driveway, about 250 years long. At the bottom of the driveway, just before entering the roadway, a few times the vehicle shifts into Neutral. At first I thought I was hitting the shifter or a bump was causing the shift, but since it now has happened multiple times, I know it is not my touching the shifter, but I am not sure what else could cause this behavior.
    Any ideas?
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Take it to the dealer. You're still under warranty.
  3. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I don't know - taking 250 years to get down the driveway may have exhausted his warranty.
    (Sorry, couldn't resist.)
  4. bisco
    51,023
    :p ^. i vote for the bump. try going really slow and see if it happens. maybe your shifter needs adjustment.
  5. Feri
    Feri Active Member
    761
    144
    It's electronic. No mechanical connection. If OP hasn't bumped the shifter then something is wrong with the transaxle.
  6. metalheart
    I tried a test, going down the driveway five different times, slow speed, fast speed, aiming for the bump. Nothing happened. However, when I called it quits and did a three point turn in the road to get up the driveway, at the end of the three point turn --- when I was in drive and wanting to move forward -- the vehicle was in neutral. I am going to document what is happening and take it to maintenance for a check out after I have some more data.
  7. bisco
    51,023
    when you say no mechanical connections, there are still some electronic contacts inside the shifter, no?
  8. Feri
    Feri Active Member
    761
    144
    Yes but those are not likely to be effected by mechanical bumping. Though if the shifter supports are not up to standard it's possible that they might contact during certain changes of direction. (?)
  9. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    This happened once to me. I was in a parking lot one day and got down on the steep part of the parking lot to get to the main road and all I noticed was that the car as if lost it's brakes. I have to press really hard on the brake. I would like to compare the situation to something like losing your hydraulics. You keep pumping on the brake pedal but is slow to react. This happened going down the steep part(really steep) of the parking lot without the engine motor running.
    OP, was your engine motor running when you experience this? Maybe you need to try this. Make sure you let your engine motor run before you go down the drive way and shift your shifter to "B" and see how it works.
  10. bisco
    51,023
    i believe you're referring to antilock brake/regen syndrome where a change in the road surface makes you feel like you've lost braking because the car is switching from regen braking to brake pad braking (around 6mph) and the abs senses the loss of traction on the road surface. however, the car remains in drive.
  11. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    When you were doing your 3-point turn, is it possible that you didn't shift into drive? I find it I try to move the shifter too fast, it won't engage.
  12. ImeanGreen
    547
    73
    Somewhere out there
    I don't think that's it though. There was no change in surface condition. Just flat steep driveway with electric motor only. Was still in "D" though. Sorry about that mistake. Did not go into neutral.
  13. Bill Norton
    Bill Norton Senior Member
    2,126
    725
    MONW, Ks.
    You can rule out problems within the transaxle.
    No shifting ever takes place in the transaxle. All the gears are always engaged. Very simple!
    The current flow and phase changes going to or coming from MG1 and MG2 are all controlled externally.
  14. metalheart
    I did not notice if I was in electric or gas engine mode, but I was for sure in D and not B. And, it is possible when I made the 3 point turn, it is also possible that I did not properly engage the shift lever into drive. So, it will take some more experience to sort out what is happening.
