Tire Leaking!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Boojoo007, Jun 12, 2013.
  1. Boojoo007
    Boojoo007 Junior Member
    64
    One of my tire is leaking, is it ok to use a patch kit? I have a Prius C -3. Will any of the sensors get screwed up?
    Thanks !
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You can use a patch kit... but only use the goop if you want to have to buy a new sensor.
  3. Boojoo007
    64
    Should I bring it to a dealer then?
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Take it to any tire place... most will patch it for free, if it's able to be patched.
  5. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Like ztanos said, take it to any good tire place and request to get it patched. (If possible)
  6. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
  7. Boojoo007
    64
    Thanks guys, i got it patched! Ran over a rivet or something. How weird.
    ztanos likes this.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Slow leaks & punctures are what happens when you run over debris. If it is in the tread it is probably repairable. If it is in the sidewall you'll be buying a new tire.
  9. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    If it's in the tire tread, you could buy a plug kit and fix it yourself. I carry plugs in all my vehicles and a small 12V air pump too.
    I ride motorcycles and have a kit on it too. You never know where you'll need it and we've needed it on some lonely
    faraway roads.
    Works great and you con run the tire until it's worn out. I do it a lot on my motorcycles.
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Most tire places will do a simple patch for free. They know that will keep you coming back when you have a real tire problem.
  11. frodoz737
    4,694
    2,496
    33
    For the record, the proper repair of a tire puncture is with a plug then a patch on the inside.
    xs650 likes this.
  12. Drdiesel
    585
    152
    Monterey CA
    Yeah! They've had to develop better customer relations to stay in business. It's nice to
    have a shop that will do it for free. It's about time, IMO!
    ztanos likes this.
  13. Drdiesel
    585
    152
    Monterey CA
    Yes! As a shop making a tire repair, it's the only proper way. As a DIY, the plug works perfectly and will last the life of the tire.
    I do it all the time and have never had a problem over the last 15 years of doing so. Most repairs have been done on
    my motorcycles due to the higher rate of motorcycle VS automotive tire vulnerability.
  14. Mendel Leisk
    41,334
    I took the plunge and did my first plug repair last winter.
    It was one of the OEM all-season tires, off the car while the snow tires were on, so no rush. The problem was a thin finishing nail, near the edge of the tread, so close that the dealership declined to patch it. I got a plug repair kit with 2 diameters of plugs, used the thinner type.
    It seems just fine, the tire is not leaking, has been back on for months now.
  15. Drdiesel
    585
    152
    Monterey CA
    In today's world, most shops won't repair tires that might be a higher risk TO THEM. Although the
    tire isn't necessary damaged, it's not worth the lawsuit to take the chance. Repair guidelines are clear
    and tire failures have become a major issue. As the industry loses it veteran mechanics due to low wages,
    you get unskilled kids working in shops with very little or no training. The owners are to cheap to train anyone
    and they don't keep people for long because of low pay and poor working conditions. The public suffers and
    tire repairs can easily be done improperly. They had a huge lawsuit over an improper repair after a family was killed
    due to negligence. The person who did the repair never buffed the tire and only used a patch. The patch came off and
    they had a major accident.
    Some places will use this as a tool to sell you something and the dealer would be the one most likely to do so, IMO :censored:
    I hate unscrupulous shops that pray on the unsuspecting consumer. In today's market, they're closing places like these because of bad reputations and that's a good thing.
  16. Boojoo007
    64
    Yikes thats scary. Mine appears fine still. I will monitor it.
    Thanks guys
