Camry Info Screen Washed Out by Sun
Discussion in 'Toyota Hybrids and EVs' started by cycledrum, Jun 18, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    What's the point of having a multi-information touchscreen that's subject to direct sunlight through the windshield? Owner is supposed to find some kind of shroud that goes between the CD slot and center vents? No room for that, plus it would block the vent air. I know it's a touchscreen and have to have it close but....
    EX-L has a touchscreen and multi-info screen under dash hood to block sun. What's up with that Toyota?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I agree with you here.
    The funny thing is in development you would think that would be an aspect they would easily and obviously test. If they did or do? I guess they don't care.
    The information screen on the Prius is absolutely useless on a bright summer day. I would have to call it poor design.
    cycledrum likes this.
  3. El Dobro
    El Dobro A Member
    7,073
    3,258
    Have you tried adjusting the display controls?
  4. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    The display brightness has nothing to do with the glare from the sun. You literally have to lean around the glare in order to read anything on the screen when the sun is just right...or wrong, depending on your point of view.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Hoods cost money. Hopefully someone will come up with a visor like the one that is available for the Gen II. I have one, it makes the world of difference!
    A major improvement would be for Toyota to start using OLED displays. They are out there, they can be fully visible in direct sun, and cost a bundle!!! Oh ouch, that last one is why you will not see them, maybe in a Rolls, or other really expensive where it makes sense to have this type of display! $300 worth it!
    OLED technology is coming down in price, the Nikon S-9500 has a OLED screen, nice! The wife has her heart and charge card set on one!
    When she gets it, I will take a pic of a regular vs. OLED screen shot!
  6. El Dobro
    El Dobro A Member
    7,073
    3,258
  7. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I found on my Prius c (somewhat counter-intuitively) that turning the contrast all the way down helped quite a bit.
  8. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
  9. El Dobro
    El Dobro A Member
    7,073
    3,258
    Yep, I adjusted the contrast all the way down and the brightness all the way up.
    mmmodem likes this.
  10. bisco
    51,031
    i would normally comment here, but i hate to agree with cd on any of his anti toyota rants.:cool:
  11. El Dobro
    El Dobro A Member
    7,073
    3,258
    You have the same radio I have, give it a shot.
  12. bisco
    51,031
    i can't, the sun's in my eyes.:p
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Thanks El Dobro. It fixed the problem. That was an amazingly simple fix for a problem I've had for the last 8 months. This should be a sticky.
