Battery not holding charge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shayla, Jun 21, 2013.
  1. Shayla
    Shayla New Member
    My 2006 Prius battery is not holding a charge very well. About a month ago I had rodents in the engine and had both my stereo and wiring harness replaced at the dealer. I've noticed that every morning the Energy Monitor screen shows only 2 purple cells left in the battery. It always recharges as I'm driving it, but then it loses its charge after siting still a few moments. No idiot lights are on. I've done the DIY system check mode and everything says OK, except audio- it shows "check" in red. Also, my 12v battery is at 11.9. (I replaced my original 12v battery several months ago with no problems).
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Welcome to PriusChat! Since the dealer just worked on the stereo and the audio shows a red "check" as in the photo, I would get that fixed first. Good luck!
