Battery issue..................HELP
Discussion in 'Gen 3 Prius Main Forum' started by MPGnutcase, Jun 28, 2013.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    when I got home from work today on my Prius 2012 the battery guage was almost full then I went out hours later it was on half? everything was off outside temp 91, ran A/C home...............
    Should I be concerned? :(
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    Does that every now and then, normal don't worry. I'm sure it is fine. :)
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    K
    Teenager kid took it out for a drive and didnt tell you?
  4. MPGnutcase
    579
    114
    Chicago
    I have a date with the dealer next week, they said it should never drop below half!!!!
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    The dealer will charge you for the inspection and not find any error codes.
    "Sorry, but without error codes we have nothing to go on. Please pay the cashier on the way out."
  6. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    It's normal for the "battery gauge" to vary from reality. It is -very difficult- to actually measure the level of charge in a battery. It's sort of proportional to the battery voltage, but so is the battery temperature. Toyota's system relies on a measure of charge in and charge out, with occasional corrections due to battery temperature, among other things. After you shut it off the battery cooled off, and the gauge measured that, compensating the reading when you next turned the car on.
    As far as the dealer telling you it shouldn't go below half, run screaming from that person!! There is a moron born every minute! The gauge can vary from one pip (and even in extreme situations 0 pips) all the way to full. That equates to about 30% charge all the way to about 70% charge. No, the traction battery is never allowed to fully charge. You need "head room" for regen. and you -DON'T- want to fully charge the battery for other reasons - one cell could overcharge and loose electrolyte which would eventually be fatal for that cell (and the battery when that happens).
    Keep remembering the battery is only 6.8 A-Hr, so it doesn't take long to charge or discharge it. It's an accumulator for short term energy, not a battery to run on for long periods of time without charging. Even the PIP can't run for long distances on the batteries.
    jonb505 likes this.
  7. MPGnutcase
    579
    114
    Chicago
    Thanks for the info David
  8. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    hmm, I've never heard of this. What dealer do you go to? Keep us posted with what they say. Are you still under warranty?
  9. MPGnutcase
    579
    114
    Chicago
    Fox Lake Toyota, Yes the car is 2 months old
