Aluminum pedal set from Ultimate Pedals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 32kcolors, Jul 3, 2013.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I’ve installed a set of custom-made aluminum pedals from Ultimate Pedals. Unlike pre-manufactured pedal sets that many here have, everything through Ultimate Pedals is custom-made to your exact specifications with options like mix-and-matching surface finishes, adding a flange/extension, custom engraving, object pocketing, etc. My primary motivation for going through them is I wanted a flanged dead pedal/footrest cover, which isn’t available with pre-manufactured sets. There’s a strip of carpet to the right of the dead pedal that is extremely susceptible to wear (which is a stupid design on Toyota’s part) and the flanged design means the metal runs over to the side, which would completely prevent carpet wear.
    After working closely with Rob Baylor of Ultimate Pedals and no fewer than 20 back-and-forth email correspondences to check paper templates, etc., I had them do custom-pocketing of my “Prius Goes Platinum” badge, a one-of-a-kind badge celebrating one million Prius sold of which only 1000 unique examples were produced that turned out to be very nice medallions, in the footrest cover (to break up the large area that it occupies). For surface finish, I selected frosted (satin) as it’s a better match to the finish on the steering wheel trim and door pulls than shiny (brushed). I also went with anti-slip without grip inserts for all the pedals. They manufactured the pedals in just three days after receiving the badge and my final confirmation (I changed my mind on surface finishes a couple of times after ordering).
    They weren’t kidding when they bubble wrapped the pedals with a packaging tape that reads, in part, “Custom made Jewelry for your Car.”
    The anti-slip surface is quite grippy making rubber nubs unnecessary, although you still have the option to add grip inserts if desired. Rob Baylor designed the parking brake pedal to be larger with 12 countersunk holes, as only four holes of which two are occupied by screws (if it were to be the same size as stock rubber cover) would look silly.
    The pedal feels right at home with the aluminum iMac, keyboard and trackpad :)
    The frosted finish (obtained by blasting with glass beads) goes well with the silver interior trim. It’s also their most popular finish.
    The “Prius Goes Platinum” badge pocketed into the footrest cover. In hindsight, I should have fudged the mileage to get prettier graphics on the badge :D
    The recess is deep enough so that the badge sits flush with the surface. The anti-slip finish, while not necessary for the footrest, provides a good contrast to the badge making it pop. They’ll allow you to mix and match surface finishes (e.g., smooth for gas and dead pedals, anti-slip for brake pedal, etc.)
    Check out this sorry state of the footrest area with excessive carpet wear. I started noticing carpet wear after about 10K miles and trained myself not to touch the footrest area/use the dead pedal thereafter (until now) but the damage had already been done.
    After thoroughly dry shampooing the area, the pedals were ready to be installed using the supplied screws (self-tapping screws in the plastic throttle pedal and footrest area; machine screws with washers and lock nuts in the brake and parking brake pedal sheet metals).
    Installed
    [​IMG][​IMG]
    Stock Pedals
    Ultimate Pedals
    In all, I absolutely love how they turned out and I am immensely impressed with Ultimate Pedals' craftsmanship.
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Now that they've done all the R&D and fabrication on your set, will they offer them to everyone else? :D
  3. Burna J
    1,068
    3,337
    53
    Long Beach, CA.
    Very nice compliment to an already sweet ride.
  4. Tideland Prius
    16,549
    Nicely done! The dead pedal is my biggest gripe. A small piece of vinyl over a plastic cover to save how many dollars? (not to mention incur carpet wear as you mentioned. Mine has been soaked with mud every Spring as the snow melts and mixes with the sand so it has 3 winter's worth)
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Sure, you just won't have to pay the one-time $25 setup/programming fee (primarily for the footrest work) as I've already eaten it.
  6. peterjmc
    917
    189
    Clarksburg, MD
    I don't see them offering them on their site yet. I suppose I'll give them a call when I'm ready to buy them. I think I like these better than the eBay ones I bought.
  7. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, it's not yet listed on the site because I'm the first one they've done, but they're priced the same as their Corolla pedals so all you have to do is order the Corolla set but specify your Prius and any engraving/emblem pocketing during the checkout process when you're asked to indicate year, make and model. Indicate that you want to use my footrest template (assuming you want the flanged design) and you won't have to pay the $25.
    DadofHedgehog likes this.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  9. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Deluxe set (which includes footrest pedal) ranges from $109 for the smooth finish to $179 for the most expensive option (anti-slip with grip inserts, which I didn't get). Mixing finishes (e.g., smooth for gas and dead pedals, anti-slip for brake) can reduce the overall cost and Rob can tell you the exact price. If you want to reduce the cost even further, you can wait for a group buy to happen in a forum and the nice thing about their group buys is they'll allow you to include any cars, not just the ones the forum is intended for. Just google "Ultimate Pedals group buy 2013" and there was one on a BMW forum that recently ended on July 1st. Otherwise, you'll get your pedals quickly (preferably before your footrest carpet gets shot to hell ;) ) or you can just order the dead pedal cover alone if you don't care for the complete set.
    Emblem pocketing cost is $15 per pedal and they can pocket anything you can think of, including:
    HSD badge
    Persona or Prius Plus badge (if you have the Persona or any of the Prius Plus parts)
    Prius badge (with the letters separated and recessed vertically into the footrest)
    etc.
    spiderman likes this.
  10. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    looks great!
  11. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Awesome pedal set. The dead pedal is the cream on the cake..!!!!
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    The Prius is now listed on Ultimate Pedals website for direct ordering.
    I believe all mods on priuschat should be accompanied with step-by-step instructions and this is no exception, so here goes.
    Tools needed:
    • Philips screwdriver (preferably a stubby one)
    • 8mm open end wrench (or better, 8mm socket with thumb wheel ratchet)
    • 1/8” and 7/32” drill bits (preferably stronger titanium or cobalt-coated for drilling through metal)
    • Small electric drill (I borrowed my father’s 30-year-old corded drill rather than use my oversized cordless one)
    • Automatic center punch (a great tool for “etching” a starter hole)
    • Pencil
    • Masking or painter’s tape
    • Level
    • Small mirror (borrow from your kid or wife)
    • Block of wood
    • Towel or blanket (to catch the many shards of metal that will fall to the ground)
    Item not needed:
    • Degreasing spray
    Tips:
    - Keep the drill bit moving before you hit the etched starter hole. This makes it less likely for it to walk away out of position on metal. It also helps to use the center punch 3 or 4 times to etch deeper dimples.
    - Align the left edge of the alum gas pedal so that it is nearly flush with the left edge of the factory gas pedal and do likewise with the right edge of the alum brake pedal to be flush with the right edge of the factory brake pedal sheet metal. This will provide maximum clearance between the two pedals.
    - I didn’t realize until after I drilled the four holes in the brake pedal sheet metal that it actually hangs crooked relative to the floor. This is where the level comes in handy. I had to re-drill three of the holes slightly shifted to position the alum brake pedal so it sits more evenly (easily done as it’s a bit larger than the sheet metal).
    - The small mirror and thumb wheel ratchet are helpful for tightening the lock nuts in the limited space under the metal pedals. You just hold the Philips screwdriver in place and turn the thumb wheel.
  13. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Does the deluxe set come with the emergency brake pedal? I dont see it saying that anywhere on there website
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, it does. It isn't advertised as not all vehicles come with foot e-brake. The Prius comes with one so it is included.
  15. Accordlayingkit
    1,616
    1,747
    377
    Cool thanks... ebrake have the 12 holes drilled in it by default like yours or u gotta request that?
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It has the 12 holes by default. The only thing the deluxe set doesn't have by default is the flange on the footrest/dead pedal cover and you have to pay extra for that (as well as for any emblem pocketing you want done).
  17. Accordlayingkit
    1,616
    1,747
    377
    Ok great... nice job on this btw
    #17 Accordlayingkit, Jun 14, 2014
  18. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I finally got around to installing these!
    I got the brushed aluminum with domed rubber inserts.
    I started by laying down some paper to prevent metal shavings from getting into the carpet.
    Then using tape and a Sharpie I marked my holes. I started the holes using an etching bit in my Dremel. (I don't have a good punch.) Then after drilling I gave it a shot of semi-gloss black to cover the scratches.
    Repeat for the brake pedal.
    The gas pedal is just plastic. You just need a pilot hole and a firm grip on your stubby screw driver. I wedged a bit of 2x4 behind the pedals while I'm working on them -- to prevent downward movement.
    Some suggested tools.
    NOTE: Put the rubber inserts into the pedals BEFORE you mount them.
    And the result:
    orenji, m3pare, Starbrand and 3 others like this.
  19. tanzir
    tanzir Junior Member
    New York
    Very Nice!!! Where did you get these pedals from ?
  20. Prodigyplace
    12,533
    11,755
    Central Virginia
    Posting 1 has a link. Perhaps the OP thought somebody might want to know where to get them.
