what am i doing wrong?
Discussion in 'Prius c Fuel Economy' started by hieuous, Jul 6, 2013.
  1. Prius NZ
    Prius NZ Junior Member
    70
    27
    Auckland, New Zealand
    I didn't see the recommended economy till I had around 2,000km on the clock. I think it takes a while for you AND the car to settle in.
  2. Drdiesel
    Drdiesel Active Member
    585
    153
    Monterey CA
    I run 42 PSI in all 4 tires. Make sure your battery vent isn't blocked by something.
    It's on the left (drivers) side of the rear seat. Open the left rear door and double check it.
    It needs to be unrestricted or the batteries will not cool off. Run the car in Eco mode
    and turn the A/C down to 65° and see how things go. Also drop your speed to 64 MPH.
    You should be able to get 46 MPG on the freeway at 64 mph with 42 psi, unless you have
    lots of luggage/extra weight on board.
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    OK, what was your mileage in your last car at 70+mph in 90+ degree heat, heat and cold kill gas mileage but the prius, be it c or hatchback still shine, look at the numbers.
    If you want an anti-gravity machine, go to sleep, dreams are great...
  4. Nel
    Nel Member
    174
    84
    SF Bay Area
    To be honest, yes, your expectations are simply too high for the given conditions.
    I also achieve below EPA because my conditions do not match the testing conditions. However, I understand that my mileage suffers below EPA regardless of what car I'm driving.
    On the occasions that I drive in better conditions, I can well exceed EPA ratings. In fact, I've achieved 67 mpg on a 100 mile round trip before. Just that my everyday route yields 44 mpg and I understand the parameters in which I'm driving usually
    Galaxy Nexus ? 2
  5. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I'm the same. Our winters are fairly mild so I actually get my worst mileage in the summer and that's due to the AC. If you're concerned about mileage in the c and you're using air con, my top three suggestions are:
    1. ECO Mode
    2. ECO Mode
    3. ECO Mode
    And check your tyres. After you've selected ECO Mode.
    I'm not kidding, if you're using AC and you're not using ECO Mode, it's going to cost you. If the car is hot when you first get in, put all the windows down for a couple of minutes to vent it down to ambient temps, then raise them and let the AC take over. It's still quite effective in ECO Mode but the car is much more sensible about how it uses it and this makes a huge difference.
    ChinchillaGirl likes this.
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    indeed.. do not skimp out and bear with the heat inside the cabin without AC (but use ECO when you do)
    the traction battery is inside the car.. and it performs better when it's properly cooled.. the engine on the other hand, likes the heat (obviously not to the point of overheating..) but anyway.. the hotter intake temperature will allow better mileage at the cost of power.
    compensating that loss of power by pushing on the accelerator more to get the car up to speed faster will hurt mileage a little bit... it may anger other drivers around you, but take it easy on the throttle when you need to accelerate up to speed.
    whenever i'm below 15 mph, i try to keep the ICE off.. so for example, when I'm accelerating from a stop, I focus on staying in EV until 15mph, and then fire the ICE to accelerate up to speed, from there trying to stay under the PWR zone on the HSI... (it's some advanced hypermiling technique or something I read about.. I don't remember any other details..)
    then there's other techniques.. pulse and glide... drive with load (which is applicable to hills)... etc..
  7. By the way hieuous, I did nearly the same highway run that you did (AC highest fan speed and LO temp setting, 72 mph, level flat highway, light traffic, did both ECO on and ECO off), and I got exactly 40 mpg. It's 93 degrees here instead of 103 degrees where you are, so your fuel economy should be just marginally lower. I seriously think that your car is performing exactly as it should. For comparison, my SUV would get 20 mpg under same conditions.
    Anyway, Let us know what your lower-speed commute is like, so we can trouble shoot that, if you still want. My past two supermarket trips, in traffic and at lights, have been in 90+ degree weather, and my overall "hot summer" city commute is also around 40 mpg.
    So, I'm really tempted to conclude that there's really nothing that you're doing wrong since it's extremely hot in Las Vegas...you guys are expected to hit 110 degrees every day for a few weeks.
    What really kills my fuel economy is that with all the tourists being up, some of them act like they own the roads... :rolleyes: So I gotta step on the gas harder. You're probably going through the same thing in your city travel. Oh well, safety over fuel economy for me.
    (Did anybody actually read all that?) :eek:
    ChinchillaGirl and PLSPUSH like this.
  8. Drdiesel
    585
    153
    Monterey CA
    Over riding the fan speed and temp settings will defeat the Eco modes control over the A/C.
    In order for the Eco mode to reduce the A/C's impact, you need to have the Eco mode turned on.
    Turn the A/C on using the auto button and set the temp to the desired setting and allow the climate
    control system to control everything else. It also helps to use a higher setting to reduce A/C impact on MPG.
    I typically use mine around 65° to 68° settings. Don't turn off the recirculation mode either.
    karabits likes this.
  9. Oh yeah but I curious to know just what the actual mpg figure would be, if I blasted the AC like that.
  10. hieuous
    hieuous New Member
    yep. you guys were all correct.
    I did the stupidest thing and drove without AC for a day in 110 degree weather, Inside the car was easily ~120 I finally hit the intended 50 MPG and hovered around 52MPG the whole day. I also kept the car at a stout 63 MPH whenever I took on the freeway. I managed a lot of middle fingers and dirty stares that day....I tried to threaten them back but asian girls just don't have that threatening stature I guess.
    I also figured that for the past couple of days between my military drills and work i've been going through a mixture of city and highway driving which probably messes with my fuel economy.
    either way, thank you. all of you. an amazing forum we have here. and i love this car more and more.
    minkus, ChinchillaGirl and ztanos like this.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    So your new mantra will be to drive normally, and think "No other gas powered car would do as well", right?
  12. Nel
    Nel Member
    174
    84
    SF Bay Area
    Safety first. Your savings in mileage aren't worth as much as the safety of yourself and everyone around you.
    Now that you know your car is doing fine and capable of being great, you should consider going with the flow of traffic again.
    And most of all, rejoice in the fact that 40mpg was disappointing to you ;)
    Galaxy Nexus ? 2
  13. hieuous
    hieuous New Member
    Definitely....I never thought about it like that. I guess that really is a good feeling after all
    SAMSUNG-SGH-I317 ? 4 Beta
  14. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    Even at highway speeds I would expect near 50, if you are only getting 40mpg or upper 30's in a Prius C, I'd take it to the dealer and advise that you're getting less than the mpg you expected and have them look at things, run a computer check to see if anything is happening.
  15. hieuous
    hieuous New Member
    highway speeds (70mph-80mph) in an area where it hit 117 last week and ac full blast?
  16. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    Only one thing you need to focus on: a visit to the dealer is free for them to check an issue like this. Its better to have someone tell you its the temperature in person after checking it, a certified Toyota technician, than just assumptions here.
    I would agree that in extreme heat like that you'll expect some efficiency loss, but how much is the question. A certified Toyota tech in your climate will be able to better assess other customer experiences and compare against yours.
    Trust the experts!
  17. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    The car is rated at 46 on the HWY... it's about right at 70 in normal weather.
  18. Drdiesel
    585
    153
    Monterey CA
    This vehicle is rated 46 MPG @ "freeway speeds" :confused: Driving 70 or 80 MPH will result in a much lower MPG.
    Taking it to the dealer will be a complete waste of valuable time. Drive it like it's a hybrid and the MPG figures will
    return to a normal rated level. Drive it like you would a non hybrid, without the MPG feedback data and it will return
    about 40 MPG. I know people that only get 36 MPG, because they drive like their hair is on fire and they swear
    it's not them. So, it must be the car :ROFLMAO: :ROFLMAO: :ROFLMAO:
    The dealer can't look at the car and tell you if anything is happening, unless the system detects a fault and records the data. No fault lights on, equals no problems found at the dealer.
    They might put you though a fuel consumption test, but I can guarantee the results will point at poor driver habits and high speed driving. Ask me how I know. I've done it to customers and they finally quit coming in for repairs that aren't available, because it's their poor driving habits that create the problem. Some people just can't accept the facts.
  19. Nel
    Nel Member
    174
    84
    SF Bay Area
    70-80 are not typical highway speeds... Hence not typical mileage returns.
    Save your time and do something good with it. Like hug your car and leave a lipstick mark on the hood
    Galaxy Nexus ? 2
  20. BJ_EVfan
    BJ_EVfan Member
    75
    29
    Buffalo, NY
    Well, I have to say that 110 degree weather is rather foreign to me, I couldn't imagine living in it. 85 degrees is considered hot here.
