Charging while raining
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 9, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    What's the best practice regarding this?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    It's been pouring cats and dogs for several days here. Charges with Toyota EVSE with no problems.:D
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    It's no problem, as long as you're using a properly-grounded electrical outlet. You should also inspect the EVSE connectors and make sure they are clean and that the rubber gasket is in place.
    When you plug the EVSE into the car, the EVSE and car communicate for a few seconds before the high voltage is energized. So a best practice is to let go of the charger after attaching it to the car.
    When you unplug the EVSE, pressing the "trigger" button immediately de-energizes the high voltage, if the car is still charging. So press the trigger, wait a moment, and detach.
    ukr2 likes this.
  4. prius_in_pa
    prius_in_pa Junior Member
    208
    27
    I assume you meant charging at a station that is not under cover. Even though it should be safe but do you really want to take that risk to gain 40 cents?
  5. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Outside in the rain? Not a problem as everything is well grounded and fault protected (especially if you have followed directions for your outside outlet). I charge in the rain at times.
    Now during an electrical storm... Different matter. If a thunderstorm pops up and I am charging I will always go out and unplug the ESEV and store it if I can even though my solar panels and the whole house is surge protected! If I know an electrical storm is coming, I delay the charging until all is safe.
  6. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    This is a good point I never thought of..............
  7. bisco
    51,832
    yup. i charge in the rain no problem. plug in to an outlet, then plug into the car. the evse has gfci.
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    During rain/snow....
    I usually plug into the car- then into the wall outlet for a recharge.
    Once complete- I unplug from the wall outlet- wait a few seconds- then unplug from car.
    Might as well be ultra cautious- it only takes a few extra seconds....
  9. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I'm not certain about this, but I believe pressing the trigger will stop the car from drawing power but will leave the power pins on the plug "hot". Stopping the car from drawing power prevents arcing when you unplug from the car.
    When you actually unplug, that is when the power pins on the J1772 plug are de-energized (you may hear a mechanical thunk from a relay/contactor on some EVSE units).
    In any case, the EVSE itself has a builtin "GFCI" (like those required in bathroom power outlets) that should be capable of shutting off the power flow before any serious injury can occur if it detects current leakage.
  10. bisco
    51,832
    correct, pulling down on the trigger stops the power to the car.
  11. hill
    8,789
    It's not a risk. That's how welders work, on the bottom of the ocean ... and salt water is a lot more conductive than regular water. I've plugged and unplugged in the rain, barefoot, untold times.
    If you look hard enough, there's STILL a video on the web of the original paddle charger set up in a fish aquarium ... being hooked up to charge an EV1. So don't worry about it. Jeez ... if you want to worry ... consider the liquid explosive fuel, prone to blow up at the introduction of the smallest static spark off the nozzle or a cel phone.
    3PriusMike likes this.
  12. Bonefish Blues
    98
    31
    Oxford, UK
    Agree - I take sensible care to keep the connectors dry but other than that I just get on with it whatever the weather.
  13. Flying White Dutchman
    4,376
    313
    best practice would be to plug it in! ;-)
    Rebound likes this.
  14. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :eek:I've read, not to charge outdoors when it's raining. My electrical connector at work is outdoors and is GFI protected. I wouldn't connect when it's raining, but I've disconnected many times. I normally turn the circuit breaker to "off" just to be safe. Something about 240V standing in water...
  15. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    There is NO RISK. Rebound is correct above.
    Plug into the power outlet, then connect the PIP OR disconnect the PIP, then disconnect the power outlet.
  16. prius_in_pa
    208
    27
    This procedure sounds like it's for a home charger. What about the public charging station where you can't disconnect the power outlet?
  17. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Then don't worry at all. The charge cable handle disconnects the voltage.
  18. Clearwater Blue PIP
    Clearwater Blue PIP Junior Member
    36
    Arizona
    I charge in the rain. I've found that there's a clever spot above the exhaust where the block fits perfectly, protected from the rain. Just ensure that the muffler is not hot. image.jpg image.jpg image.jpg image.jpg
