My impression of 4,102 mile trip
Discussion in 'Gen 3 Prius Main Forum' started by TwoUnderPar, Jul 12, 2013.
  1. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Just returned home last night from an 8 day, 4102 mile trip. States included Iowa, Missouri, Arkansas, Kansas, Colorado, Wyoming, Montana, Idaho, Washington, and South Dakota. The first part of the trip was to pick up my son at the airport in Kansas City, drive down to Table Rock Lake and enjoy 3 days of slalom and barefoot skiing. The rest of the trip was to get his vehicle out of the airport parking garage in Spokane, Washington, spend a couple of days in Idaho at his place, and then come home.
    I was expecting somewhat poorer mileage with the Prius since I knew we would be moving quickly on the Interstate. Before starting out on the trip, I blew the tires up nice and firm and dropped the 0W-20 oil and put in 5W-30. The cruise control was set on 80/81/82 mph a lot of the time in Kansas, Colorado, Wyoming, and parts of Montana. I also cruised 75-80 mph much of the way home across South Dakota. Overall mileage for the entire trip was 47 mpg. This was 2 or 3 mpg better than what I would have guessed before leaving. Temperatures ranged from 104 degrees (day-Kansas) to a low of 54 degrees (night-western Montana). We used the air conditioning almost all the time, although the cooling system is so good on the Prius, the fan was usually set on it's lowest setting.
    Gas prices varied widely. The highest paid was $3.67 per gallon, the lowest was $3.09. Hat tip to southern Missouri for having cheap gas! :) The entire gas bill for the 4,102 miles was $301.00. Absolutely amazing to me.
    This was the first time that I really used the "B" engine brake mode. It performed wonderfully and prevented a lot of brake pedal use, except on the steeper grades. It appeared that using "B" would provide enough braking force to control speed, except on grades approximately 6 percent or greater. My son was intrigued with that, and quickly caught on to using the "B button" instead of the brake pedal.
    Something I hadn't counted on was using the "Power" mode to speed up accelerator pedal sensitivity while in the mountains. It made driving in the mountains more comfortable by reducing pedal travel and the amount of work needed from my right foot.
    Road noise and the sound of the Atkinson cycle engine did not bother me but my son did comment on it a few times. Maybe I had just gotten used to it. I would say it was "noticeable" but not a "nuisance".
    My condolences go out to the Prius owner that got hit, just north of Denver, on Sunday, July 7th, in the late afternoon. A genIII Winter Grey Prius hatchback got rear-ended by a full size pickup truck pulling a horse trailer. The wreck pancaked the back of the Prius and made it undrivable. Very sorry to see a fellow traveler end up in a situation like that. It appeared that all humans and horses were without serious injury.
    All in all, a wonderful trip.
    burstaneurysm, Kino, Chazz8 and 3 others like this.
  2. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Nice trip report.
    I was a little confused about the oil change though, wouldn't going to a heavier weight oil reduce fuel economy(if only marginally)? Or was the idea to better protect the engine for the extra abuse of a 4000+ mile road trip?
    Or maybe I don't know as much about oil as I thought I did :)
  3. TwoUnderPar
    TwoUnderPar Member
    78
    72
    I put a little heavier oil in it because I knew we would be running 80+ miles per hour for long periods of time. I'm guessing we likely put 900 - 1,000 miles on her going over 80. That is why. Did it make any difference? Probably not, but I felt more comfortable, especially during the 104 degree temps across Kansas. I'll drop the 5W-30 and put 0W-20 back in this Fall.
    My main concern was not fuel economy.... otherwise I would have driven 65 mph (or less). :D
    jonb505 likes this.
  4. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I would have satayed with 0-20w it would have been fine
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Thanks for sharing the details.
    I'm surprised that your mpg is up in the high 40s driving at 75-80 mph. My trip to LA from SF yielded low 40's.
    I agree that 5w-30 wasn't needed... but it's your car.
  6. Sfcyclist
    1,621
    376
    SF, CA
    oh.. was the mpg per MFD or calc'ed?
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I averaged 80+ mph on my 1000 mile road trip. And I got slightly above 47 mpg. I have a PiP but without plugging in, the fuel economy is only a hair better. I was also expecting fuel economy in the mid to low 40's.
  8. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Mpg was calculated. The Prius was telling me it was 49.x (almost 50), but I kept track myself. Even at 47 mpg, I was impressed.... but at the same time, if 1,000 miles were at 80+ mph, that still means that 3,000 miles were slower than that.
    I respect those that comment on the oil change. I don't doubt that it likely made no difference at all, other than my own personal feeling. As an engine builder in a past life, that 0W-20 just strikes me as being "water" and I'm apparently just getting old and set in my beliefs. :LOL: As stated above, when the weather cools down, I'll put the 0W-20 back in.
  9. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I concur, NASCAR racing uses 0W-50 Mobile 1 oil.
    [quote=" As an engine builder in a past life, that 0W-20 just strikes me as being "water" and I'm apparently just getting old and set in my beliefs. :LOL: As stated above, when the weather cools down, I'll put the 0W-20 back in.[/quote]
  10. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I did a 550mi trip over the weekend from NY to PA then back again.
    4 ppl w/luggage for an overnight stay and a donut spare in the trunk- averaged around 65+mph most of the time w/the AC on the whole time- ended up at 54mpg at the end of the trip.
    retired4999 likes this.
  11. jgilliam1955
    368
    102
    Williamsburg, Virginia
    wow nice trip
  12. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Your numbers match up almost perfectly with mine from my trip from VT to NC and back again about a year ago. Overall MPG on the screen was right at 50, hand calculated was 47.X. It was me and a buddy, moderate luggage and a cooler and we just blitzed down 95 the whole way. Got our best tank through NYC going south as the speeds were slower. Highest speeds (80ish) were farther south but it was quite flat by then so it helped. Onboard MPG display was in the low 50's until we hit the really fast highways and then it ticked down. Lots of around town running around in the Raleigh area in there as well.
    I didn't find the car or tires (which were pretty worn OEM Yokos then) to be overly noisy and we were both very comfortable in the seats. It was his first extended trip in, and driving, a hybrid and he came away very impressed.
    I wouldn't hesitate to drive this car cross country.
    TwoUnderPar likes this.
