Battery Temps
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jul 14, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    Wondering if there is another factor involved here...such as the wrong gauge. I'm routinely seeing battery temps in the mid to low 90s even when it is pretty warm weather and I am in EV. Is this possible? On my old Gen3 even when I use the battery just a little bit on warm days it would go over 110. Does the lithium chemistry just keep it that much cooler? Or does the cooling system keep it that much cooler? Or both? What are other people seeing for battery temps?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  3. markabele
    5,084
    1,782
    Nebraska
    F
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I was monitoring 3 of the battery temps. They were all relatively close in temp, IIRC
    I havent "Torque'd" in a while.. but here's a graph I made for my 9/25/2012 drive:
    I dont remember, and didnt log, what the external temp was.. but being late Sept, it was probably on the warmer side.. maybe mid-70s to low 80s?
    I found the historical temp for that day and it was a high of 78F
    My battery temps rise at the end because thats where speeds pick up (55MPH) and I start going up hill.
  5. markabele
    5,084
    1,782
    Nebraska
    So why are mine so low? Granted I virtually never get it above half the HSI bar and that's only during acceleration if someone is behind me (rarely) so usually it is a quarter of the bar or less. Could that have something to do with it? Or am I getting bad numbers somehow?
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Here's another from 11/13/2012. The historical temperature for that day shows a high of 83F. It doesnt seem right though since my battery temps started at about 87-88F. Back then, I was kind of parking in the sun.. very little shade until late in the afternoon.
  7. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I dont think your numbers are bad.. probably as you pointed out, your driving style.
    Looking at my November 2012 graph, see where it plateaus? On that portion of my commute, speeds generally pick up (50MPH posted). But that section gets congested from time to time. It appears that day is was congested since the temps didnt spike like they did my my previous example.
    I think with somewhat conservative driving,t he temps wouldnt go up as much or as quickly. Also seeing as how my battery temps dropped a bit in between the two spikes (in the Sept 2012 example), I bet my AC was on.. or at least I turned it on around that time.
    I havent logged in a while.. I'll try logging some data this week since its kinda warm here.
    markabele likes this.
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It should start close to outside temp. It takes a lot of energy to increase the temp of the battery pack. The loss of Lithium is pretty low so you may not even see the fan running.
    From my monitorings, I have never seen the battery fan go on.
  9. markabele
    5,084
    1,782
    Nebraska
    Wow, seems like my old Gen3 batt cooling fans used to run quite a bit.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Isn't the PIP also Gen 3 ?
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes!
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes but, Battery tech. is different. in plug in. Lithium runs cooler maybe? so less fan? or the extra fan and vent keep it cooler?
  13. Andyprius1
    2,327
    859
    Cool CA
    Niether my 2005 nor the PIP run the fan, but, that could be mostly because the cars stayed in the garage most of the day. I run the AC when it's hot, which benifits the car also. I went thru a period where I was monitoring the temperatures of the engine coolant and was amazed how low they were compared to a typical ICE machine. Inverter temps were even lower at around 90 - 100F, as I recall. The Prius is a cool running car. Keeping those cooling (fan) ducts open and unblocked is very important in hot weather and/or hard use.
  14. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Anyone have any charts of battery temps while charging? I did not find any with a quick search of the topic here.
    This may be useful for winter EV driving if it shows battery temps are significantly warmed up near the end of a charging cycle. Right now I complete charging at night a few hours before I go out to work in the morning, but if the battery was nice and warm at the end of a charge cycle, I would have it complete right before I left for work to see if that would help EV range.
  15. bisco
    51,840
    i've never really noticed a difference between cold battery range or warm. nor the ice firing or not. it all seems to be external conditions. but there might be small variations measurable only by instrumentation.
  16. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    You mean your acutal or estimated EV range has been unchanged by the cold temperature of the battery? I think most of us see real and estimated EV range decrease in the winter when battery and outside temperatures are colder. One of the theories is that the cold battery temperature is primarily the culprit. Are you suggesting this may be another phenomenon not related to battery temperature?
  17. bisco
    51,840
    i'm suggesting that it's the cold ambient temperature controlling actual ev distance and thus ev range estimate. i believe that if it's 30 degrees outside, and you charge inside a heated 75 degree garage, the outside temp as you drive will affect the range by 99% and the heated charging by 1%. not scientific, just observation.
    giora likes this.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    wouldn't it depend on how long it takes for the battery temp. to drop from 75 degrees to 30 degrees?
  19. markabele
    5,084
    1,782
    Nebraska
    If the battery is currently getting used, it isn't anywhere near 30.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    agreed......it's only when you stop and park for awhile, for instance at work when it makes a difference.
