NHW20 brake pause problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bwilson4web, Jul 18, 2013.
  1. bwilson4web
    15,936
    When we were shooting the ZVW30 brake pause problem, I remember some posts about a similar thing with the NHW20. As a reminder, when going ~18-19 mph and hitting a significant bump (speed bump) on a slippery road (aka., rain dampened,) the unpatched, ZVW30 brakes would 'pause for ~800 ms. But even though that problem was fixed with a patch to the brake controller, I remember seeing a couple of posts that the NHW20 had something similar.
    Any insights?
    The reason for my question is a Virginia resident has a new assignment that involves a significant daily commute +100 miles per day. I told him about the $64 hybrid tax and he is aware of the Virginia $20,000 personal property sting. I suggested a 2004-09, especially the 2008/09, would be a good option:
    • cheap enough to avoid the Virginia personal property tax sting
    • efficient enough to handle the Virginia $64/year "whack a hippy" tax
    Thanks,
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Yes gen 2 has a similar problem that when there is a bump or a slippery patch on the road, the re-gen braking would cut out and it seems to require more brake pedal pressure to achieve the same (now only frictional) braking force as before the re-gen cut out. (thus giving the driver a sensation of braking loss/failure or even "unintended acceleration".) I can dig up some data later.
    bwilson4web likes this.
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hybrid tax? Holly crap, I never knew about that one. Do you get a tax credit if you can prove that you polluted a river or something. Or maybe show receipts to prove you sprayed a enough cans of cfc aerosols. What a crazy idea. :confused:
  4. bwilson4web
    15,936
    Never forget:
    Winston Churchill
    PriusChat actually has at least one 'claimed' Prius owner from Virginia defend this "whack a hippy" tax. Actually, the kid is the punch line for every joke ever told about Americans from the USA. If he wanders over to this thread, feel free to ask the 'setup' questions. <grins>
    uart likes this.
  5. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    The VA tax is supposed to replace the lost fuel tax revenue. As hybrid and electric vehicles continue to proliferate, this type of thing is going to become more and more popular. AFV owners are seen as "cheating" the taxman.
  6. 2009Prius
    2,705
    511
    63
    Now I think of it, it is bad programing, isn't it? It is understandable that the engineers wanted to cut out re-gen braking to protect the MGs from over-revving when there is slipping. However the ECUs could have been and indeed should be programed such that the same brake pedal pressure always gives the same total braking force, no matter the source (re-gen or frictional or both). It was programmed correctly under normal braking condition when re-gen switches to frictional braking at low speeds. It was obviously programmed not very well for the slipping condition.
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It's interesting that some people are extremely disconcerted by this "feature", while others are fairly ho hum.
    I know that I've experienced this issue from time to time, but it's never been a real big deal for me. The first time it happened was a bit unsettling, but I kind of got to used it. Some people however have literally gone out and sold or traded their Prius the very next day after it happened to them!
    The circumstance under which I notice it most clearly is where you cross over ridge or discontinuity (like a rail line etc) that runs obliquely across the road (so that the front wheels contact it at different times,) and you're braking moderately, but still light enough to be fully regenerative.
  8. 2009Prius
    2,705
    511
    63
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    I don't think my car ever got that brake patch. Was that a TSB available? Just software?
  10. 2009Prius
    2,705
    511
    63
    I think the patch that Bob mentioned was for gen 3, not our gen 2 Prius (though there should be one IMHO).
  11. edthefox5
    10,096
    4,829
    Clearwater, Florida
    Oh ok thanks 2009.
