2010 Prius only getting 32 mpg due to wheels/tires...need recommendations on replacements
Discussion in 'Gen 3 Prius Accessories and Modifications' started by GoldenKiwi, Jul 20, 2013.
  1. GoldenKiwi
    GoldenKiwi Junior Member
    Feels great, have you tried it?
  2. GoldenKiwi
    This was my first time actually calculating the mileage, but as I mentioned in another post I am familiar with my mom's 2010 Prius and mine has been getting bad mileage the whole time I've had it, driving under varying conditions. I have not reset the fuel meter. Here's a screenshot of my mpg display, not sure how this compares...
  3. peterjmc
    917
    189
    Clarksburg, MD
    A/C on with the windows down does feel great. I loved it when I had my Cobra and Subie and enjoyed the sound of exhaust rumble. I do it less with the Prius because, well, there aren't any exhaust notes :).
    I agree that storing your bicycle inside the car doesn't add any significant weight to kill y our MPG.
    I'd focus on looking at your tires, and driving habits. I like to keep my eye on the MPG meter that's to the right of the speedo on how heavy I'm pressing down on the gas pedal. I focus on trying to keep that as close to 50 or higher as possible.
    I'm assuming that you've checked your tire pressure and at a minimum, they are at 32psi?
  4. GoldenKiwi
    My tire pressure checker is out of commission...is it possible to get it checked for free somewhere?
    EDIT: Got it checked at Pep Boys. It was at 35 front / 33 rear as recommended by Toyota.
  5. xcuter
    xcuter Active Member
    303
    182
    Come up to L.A. I got a sweet of stock 15's you can test out Kay to see of its ready your ruins or not. I'll jusy hold your rims as collateral. :D
    SPH-L900 ? 2
  6. GoldenKiwi
    Thanks, but at this point I'm not interested in the 15s...I'll let you know if I change my mind.
  7. U2NVME64
    U2NVME64 Junior Member
    77
    25
    Just think of it this way, no matter what you do with rims and tires, you won't be taking any kind of hit in MPG. Anything will be an improvement on that kind of MPG. I'm running stocks without the the hubcaps and I think it looks fine, plus I average 58.7 MPG.
  8. GoldenKiwi
    An extra ~10 mpg just for removing the hubcaps? I've never heard of such a thing...I'm guessing you also drive very conservatively right?
  9. U2NVME64
    77
    25
    Oh no I didn't improve MPG by removing the hubs. I removed the caps because the black rims under look way better. I get that kind of MPG all the time. Not a hyper miler but my Pri gets good gas mileage. I'm usually somewhere between 65 and 80 MPH on the freeway
  10. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    I would focus on your driving habits a bit more before spending more money on analysis, tires, and whatnot. I have had my 2010 for 2.5 yrs and my MPG can vary from 32-49 and it is all about how I drive the car.
    I have aftermarket tires (not as big as yours). When I am only driving to the train station and back (typically 2 mile super race bc I am always running late, stop and go for traffic and lights) well that is when I get 32.
    On other occasions, my daily commute was 45 miles each way, a lot of freeways, almost no stopping my average was >48 and climbing. The more you drive the car and pay attention to what is happening, the easier it will become to get to those higher numbers.
    That said, remember to drive safely as opposed to hypermiling. The $3 per tank savings when "Driving Mrs Daisy" is not worth getting into an accident or being the Prius that caused it.
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Get a working pressure gauge and try tire pressures closer to 36 or above. I run 40 psi but it's a little harsh, even with the 15".
  12. ursle
    ursle Gas miser
    1,049
    192
    NH
    Open windows, air on, 18' wheels and you wonder why your mileage sucks, stop trolling
  13. xcuter
    303
    182
    Kinda harsh man. :mad:
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The OP isn't trolling, just uneducated on the various factors that impact mpg. There are even 15-wheel Prius owners who've bought into tire shops' lies that their recommended non-LRR tires are the much better replacement only to watch their mpg disappear into thin air.
  15. JuRuKi
    JuRuKi Junior Member
    61
    get some lightweight Volk ECO wheels and LLR tires
  16. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    get some 16's corolla oem
  17. fuzzy1
    10,391
    Were the tires morning cold, or had they be run long enough to warm up? If the former, you can do better with more pressure, but it will come at the cost of ride harshness. If the latter, then your tires are definitely underinflated. Check them again first thing in the morning, while they are still cold.
    Also, try this questionnaire: Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
