2003 Air Conditioning Clutch
Discussion in 'Generation 1 Prius Discussion' started by Cpbender, Jul 25, 2013.
  1. Cpbender
    Cpbender Junior Member
    Swarthmore, PA
    2003 Prius
    My 2003 with 150K miles has had the blinking A/C light problem for the past year or so. I've read many posts on the subject, including Station2Station's A/C Diagnosis and Replacement Blog (which is awesome, thanks). I ran the diagnosis, got the 22 code, so it seems the clutch needs to be adjusted or replaced. One difference with my situation from everything I've read: if I leave the A/C on Max with the fan on at Max, the A/C works fine (for at least as long as my daily commute, about 40 mins). Once I turn the fan down or turn Max off, the lights start blinking within 5-10 minutes and the A/C doesn't work. Is this consistent with the clutch problem? The Dealer wants $150 just to diagnosis it, and my normal mechanic doesn't really know what to do with it... I won't be attempting the repair myself, but want to give my mechanic as much info as possible (unless, of course, there's somebody on this forum in the western Philly suburbs who would like to take this on -- let me know if so). Thanks!
  2. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Yes it sounds like your clutch..Mine did the exact same thing..Once I put on a new clutch the problem disappeared..
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    You can re-gap the clutch to save money.
  4. Cpbender
    Swarthmore, PA
    2003 Prius
    Good deal, thanks for the responses.
  5. lech auto air conditionin
    830
    602
    261
    san francisco
    y you can re gap the clutch with shims only after removing the belt and spinning the pulley to feel that the bearings are good. re-gaping the clutch then having the pulley bearing fail 10,000 is a waist of money and a waist of time.
  6. Cpbender
    Swarthmore, PA
    2003 Prius
    thanks Lech, I appreciate the advice.
