Front license plate
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 510bg, Jul 26, 2013.
  1. 510bg
    510bg Member
    142
    Have any ca owners been able to zip tie the license plate to the front grille? I'm trying to avoid drilling the bumper. Seems like I would need to trim the license plate to fit properly.
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Mine came with a proper license plate holder. I would think that is standard in CA where a front plate is the law.
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Rockerdan used the stock front plate mount in the lower grill area. Here's his thread:
    Rockerdan's Plug-in thread | PriusChat
    Post #10 he kind of explains what he did:
    And a picture:
  4. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    There's a company you can find online that makes custom motorized hideaway plate holders that slide underneath the front end of the car. A friend has one on his Corvette. So if a cop pulls you over, you push a button and the plate pops into place. Now if the cop is going the other way and sees no front plate and pulls you over, you might have some 'splainin' to do. :p If the dealer installed the bracket, you have to plug the holes as Rockerdan did in the picture above.
    Motorized Hide Away License Plate Holder Motorized Hide Away License Plate Holder [motoplatehold] - $139.00 : Swift Motorsports, Import Performance Starts Here
  5. 510bg
    510bg Member
    142
  6. Crankykentucky
    Crankykentucky Junior Member
    65
    Midwest
    Careful about having a dealer attach the front license plate holder in their shop. Mine is off center thanks to the crappy job of a guy who can't follow instructions. If your Prius comes with the license plate bracket in the cargo area, take a sip of a good wine or a premium beer and attach it yourself. The holes are marked lightly, but check the measurements to be sure. I should have attached mine in the driveway!
  7. 510bg
    510bg Member
    142
    Thanks everyone going to try rockerdans method.
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
  9. 510bg
    510bg Member
    142
