Vehicle warm-up behavior - ScanGauge observations
Discussion in 'Prius c Accessories and Modifications' started by mdgates, Jul 20, 2013.
  1. koipond
    koipond Member
    198
    40
    the warm-up really drives me nuts. Partly because as folks say, short commutes (unless they come right after each other while the engine is still warm from a previous trip) are destined to be in the 30s and 40s for "no good reason". I'm really confused... what's "the point" of warming up the ICE? If the battery is full, and you're driving moderately such that the battery could handle the load, what does it matter if the ICE isn't "warmed up"? What's gained?
    Since our cars are basically drive-by-wire, and that wire is talking to a CPU that in turns powers the car, it seems like a software update could be use to "tune" the algorithms that govern the ICE/electric decision making.
    One added thought... given it's current "warm up" requirement, there would be nothing gained by convering a Prius C to a "plug in" IMO because 99% of the time my battery is *already full* and my ICE is still churning away because I'm starting a trip with a cold ICE engine. Would would having plugged my Prius C overnight have accomplished? One bar more of charge on a battery that the car's CPU isn't letting me use anyway????
  2. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    ^^^showing my Gen3 ignorance here, but for Gen2 we could get a after-market EV button. Is this not an option for Gen3?
  3. mdgates
    mdgates Junior Member
    67
    Buffalo, NY
    Koi: I share your frustration. The warm-up behavior is primarily in order to meet emissions regulations, which is not always the same thing as reducing emissions. For example, on very short trips, the goal should be to reduce the amount of time the engine is running, rather than to warm up the catalytic converter quickly. I wish the regulations were written in terms of the permissible amount of HC/NOx emitted during warm-up (which would result in better emissions systems on the larger engines that pollute more) rather than the number of seconds after starting the car (including time that could be spent with the engine off).
    So, I'm probably going to implement this, or one of the microcontroller-based ones:
    another thermistor hack | PriusChat
    Tracy: We have an EV button from the factory. If the engine is <20°C, the button just yells at you. If the engine is <65°C, you can go up to 9MPH in EV mode. Not nearly as useful as it could be.
  4. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    ...sort of amazing, Prius is...if they gave preference to fuel efficiency over emissions we'd all actually be doing ~55 MPG all the time.
  5. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    Is there any evidence that the warm-up lowers overall mileage? The thermistor hack was posted 6 years ago...has anybody tried it? There is a lot of anguish over having to replace an HV battery...I wonder what replacing an engine would cost.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Are you questioning if the engine running vs the engine not running will change the MPGs?...
  7. Mendel Leisk
    40,483
    We got the block heater install by the dealership at time of purchase, and use it regularly. I only wish Toyota would put these in at the factory, in all the vehicles. It's a relatively expensive, hard to access hassle to do the install later.
  8. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    Especially PiP could optionally keep engine block toasty warm as a side benfit since you are plugging-in the wall anyways give a slip stream of electric to the engine block, perhaps after the main charging is completed.
  9. drysider
    823
    335
    Liberty Lake WA
    I am questioning whether anyone has any real evidence that shortcutting the warm-up procedure results in better mileage. It could be that a proper warm-up will result in quicker, higher mileage than would otherwise be attainable. Not running the engine would make it difficult to warm it up.....
  10. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    ah, that makes sense. I was wondering where you were going with that, lol. My thinking on it is, why do I need to warm it up, if I don't need to? Why not let me stay in EV until I need the engine and then start the warm up, instead of just automatically doing the warm up.
  11. drysider
    823
    335
    Liberty Lake WA
    That makes sense, but may not give the best overall mileage. Pulse and glide is not really intuitive, but it works. That being said, if you press the EV Mode button within a few seconds of starting the car you can get into EV before the warm-up.
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    For a max of 9mph because the engine isn't warm...
  13. Mendel Leisk
    40,483
    It's hard to work a block heater effectively in a Prius Plug-In.
    First off, the block heater typically has an independent plug-in, dangling through the front grill. We use ours on a timer, and start-up times are pretty predictable, so...
    But with the PIP it's hard to see a good strategy for using block heater. If the vehicles running EV mode for 10~12 miles, much of the raised coolant temperature is going to be dissipated, if and when the engine does start.
    Unless you can delay EV? Run the engine (prewarmed somewhat by block heater) for the first leg, then EV for the remainder?
  14. mdgates
    67
    Buffalo, NY
    A family friend recently retired her Prius at 225,000 mi with a perfectly healthy ICE and a dead HV battery. With that many miles and being due for a $3000 repair, the car may have gone from the auction to the junkyard. I fully expect my ICE to outlast the car, whether it warms up at 1300 RPM or 1800 RPM.
  15. drysider
    823
    335
    Liberty Lake WA
    The thermistor hack might put your expectations to the test.
  16. mdgates
    67
    Buffalo, NY
    I don't wish to belabor the point, but I think my expectations are justified. Conventional Japanese vehicles built 20 years ago with conventional warm-up schedules regularly go to the junkyard with >180k+ on the clock. These are engines that had hard lives: 6000 RPM redlines, slow starter motors, 5W30 in the dead of winter, etc.
    I tinkered (carefully) on my old Subaru and my Honda Insight, without doing any mechanical damage to either of them.
  17. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    My commute today, 37F temp, no heater on but heated seat on for driver. I started the car and left in about 45 seconds driving in normal mode. I hit every green light (6) so speeds were from 30-45mph. The car takes a beating until it gets warmed up... If I go 7-12 miles I see 53-59mpg according to the end of trip summary. http://i391.photobucket.com/albums/oo354/kenscott30/Mobile%20Uploads/image.jpg
    Turn off signatures in Tapatalk Tapatalk
  18. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I think some of you are frustrated that Toyota's goals and your goals are not always the same.
    Toyota is trying to build the cleanest internal combustion powered car ever. They do it well.
    Once the engine is warm, Toyota has found that the less gas you use, the less emissions are produced, so the Prius is very frugal once warm. If you bought your Prius solely for micro-economics, this is the phase where Toyota and you have the same goals.
    However, Toyota clearly feels that when starting up, the quicker the catalytic converter attains operating temperature, the less the Prius will pollute. This may, or may not be a priority to you, the owner. It is almost a certainty that the thermistor hack is causing pollution the stock Prius would not emit.
    Now it gets hazy, bureaucratic deals were cut with CARB. If the Prius had been focused on MPG when in start-up, but lost years of HOV access, would owners be better off? (just an hypothetical example, the example I read in the committee meeting is this. The safety bureaucrats wanted a much stronger desire to go backwards in Reverse than HSD could achieve, so owners could tell they were in Reverse. Toyota offered to make the car beep in Reverse if they did not have to redesign the HSD. So a million owners hate a beep that saved the HSD, we would be using IMA or something. That beep we all hate may save us 5 MPG, as IMA was not as good.)
    But yes, if you only analyze what happens to MPG in the first 5 miles, Toyota made the wrong choice.
    Corwyn likes this.
  19. fjpod
    fjpod Member
    419
    72
    New York
    In my situation I do a lot of crawling on my short commute to work. I always let the initial warm-up to 103f take place. I installed the temperature hack and often after 103, I will use it to keep the ice off. If my traction battery is a bit low I will force the ice on when I am moving. If the soc it's up, I will just crawl with no ice. This hack had helped me improve mpg on my short trips
  20. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    1) That warm-up logic was written by some of the most knowledgeable people on the planet with regards to the Prius engine and its peculiarities. It is unlikely in the extreme that you could improve them. And any change will be a trade-off, what are you prepared to give up?
    2) Engine block heaters trade energy from electricity for energy from gas. Often at a terrible exchange rate, especially if you leave them plug in all night. Work the numbers for yourself, but for me, it would have been twice as expensive and more polluting to use a block heater.
